Question about Roper REX4634KQ Electric Dryer
No heat from our REX7648KQ electric dryer.
The other day I went to use the dryer and it would not start. When my husband got home he went downstairs and changed the fuse in the circuit breaker. I pushed start and it ran for a few seconds and stopped again. I replaced the fuse once more and it is running, however there is no hot air, only cool. Is there are reset button, or what could this issue be? Are we better off to buy a new unit this one is about 7 years old.
  • 291 Answers
I couldnt bring up this model # Is it 22ov?full size dryer? I would recheck fuse's should be 2 one for each leg of 110v . I would check to see if you have 220v to back of dryer where the cord mounts to dryer Also some models have themal fuse on burner of dryer in back, this will keep heater from coming on... You can hook the wires together, that hook to themal fuse, being careful not to short wires and test if heater will come on
Posted on Sep 17, 2007
SOURCE:
Enviro temp electric water heater started making the water TOO HOT. Is this dangerous? I'd like to get this fixed instead of replacing it if we don't have to. It has served us well up until now.
yes it is dangerous code allows up to and not exceeding 125 degrees. this link will point you in the right direction. I keep my water heater at 120 degrees
Aug 04, 2018 | Cars & Trucks
My dryer will not turn on
Several different possibilities. Tripped breaker, door switch, start switch, timer, motor, thermal fuse, and maybe more. Might need to call service for it.
Sep 09, 2017 | Dryers
My kenmore dryer model #11069202990 is no longer putting out heat in the cycles--it's still running, just no heat at all. I am trying to obviously find the cheapest route to get it fixed. Sears was...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 05, 2011 | Kenmore Dryers
My kenmore dryer modle # 9758920 tumbles but won't
ther is heat fuse on the fan unit and the heat unit check them and then you good :)...take power off first!!!
Dec 31, 2009 | Whirlpool LER5636P Electric Dryer
Dryer won't stay running, shuts off after a few minutes.
Maybe the timer or wires not hooked up right or motor if u hear like a buzzing sound when u push start it's the motor
Oct 30, 2009 | General Electric DWXR463EGWW Dryer
Elec. in garage went out, heat from dryer didn't go on
Check the wall plug voltage for the dryer outlet with a voltage meter. The two holes on opposite sides of the wall outlet should read around 240V. Either of the two outside holes to the middle hole shoul dread about 120V. If your readings differ from these it's likely you have a problem with the fuse/breaker associated with the dryer or the person who fixed your heat made a wiring mistake.
Oct 03, 2009 | GE DBXR463GB Gas Dryer
Started dryer at 6 am, got home at 5pm it was still running
if it was set on timed dry replace timer if it was on auto dry check element thumbs up
Aug 12, 2009 | Kenmore 62882 Electric Dryer
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Will start and run, but no heat.
These units have two circuit breakers...generally hooked up in tandem. It is always possible that the heater element is out. Sometimes they open a breaker when they fail. If you see a wiring diagram on the back of the unit and are handy with a multimeter...available at the hardware store...you can trace this out. Remember to turn off the power if you do.
Sep 16, 2007 | Roper RES7646KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
75 people viewed this question
Top Roper Dryers Experts
Marvin
Marvin
Dennis Boxerman
Colin Stickland
Colin Stickland
Are you a Roper Dryer Expert? Answer questions, earn points and help others
