Question about Nokia 6288 Cellular Phone
N 6288 Blank Screen and skewed graphics
I think the ribbon on my phone is damaged as when I open or close the slider the graphics sometimes skew or the screen goes blank, sometimes coming back and sometimes not. Also the 4 way button causes the same sometimes. How do you get in to the guts of the phone to take a look at the ribbon.
  • 3 more comments
  • Anonymous Feb 20, 2008
    Screen has gone completly blank. Phone is functioning normally. I can recive calls, messages, play music. But cant see a thing on the screen. No icons are visible. Dont know what to do. Tried to take out the battery and put it back again. The screen came back. But the next day it was gone again. And now it seems its gone forever. What a pity. THe phone is so good
  • prasawasa Aug 10, 2008
    same prob;em but is there a way of fixing it without sendong oit to the okia technician??
  • Candycane-x Aug 19, 2008
    have the exact same problem. some times i take the battery and sim out then replace it, occasionally that worked but not always. I dont want to have to send it in, couldnt live without a phone!!
  • cozmo_email Oct 17, 2008
    same problem over here. screen is completly blank (black) even. power is on, all functions work. it is just a problem from the small lcd screen. the funny thing is that this happened to me over night, literally. when i went to bed I set the alarm clock on the phone, and in the morning (when it started ringing) the screen was all black. the battery in/out or sim in/out didn\t work for me. I'm gonna see a technician.
  • Anonymous Mar 20, 2009
    My screen went blank after upgrading my firmware few days before that.
It just happened to me yesterday and all I did was to send my phone to a Nokia technician and he just replaced the ribbon in it and it is now perfectly fine!
Posted on Sep 23, 2007
The front screen of my Nokia 2720 is just blank, how do I get to work
The micro ribbon wire may be damaged if its blank if the phone is old this may be the case opening and closing breaks the ribbon wire after time. If it is new return for replacement. also in menu, phone, display is where all adjustments are.
Apr 06, 2012 | Nokia 2720 Fold Cell Phone
Hi there. Our Canon ImageRUNNER 3235i has been skewing papers about for months. Service techs can't seem to find the problem as it is sporadic. Any suggestions?
These can be a quite pain, this copier when it works it works it fine, but when it doesn't works it doesn't work with style.
Please give me more info, where the paper is skewing? in duplex assy or before or after the fixing unit or while going out of paper drawer...?
I had a problem that paper was skewing in duplex and I've chaneged the duplex vertical roller axis.
Sep 20, 2011 | Canon ImageRUNNER 3235i Black and White...
HOW DO YOU CORRECT A SKEWED COPY ON THE COPIER? HAVE CHANGED REGISTRATION ROLLERS, SKEW IS SAME FROM ALL TRAYS & BYPASS. TRIED ADJUSTING THE FOCAL LENGTH ON THE MIRRORS, AND STILL HAS ABOUT 1/8 INCH...
First you need to determine if it is optical skew or mechanical skew.
If the machine is used as a printer then do the computer prints come out skewed? If it is not connected to a PC then print out the counter list using UserTools/Counter. If that prints straight then you are dealing with optical skew. Ricoh's in general are bad about the left front corner of the machine drooping from someone pushing down on that corner. If you have optical skew try lifting up the left front corner of the copier and try making a copy. That might fix your problem.
If the UserTools/Couter print out is skewed then your back to a mechanical skew and there are numerous causes for that.
The optical skew is more likely so let's start there.
Nov 18, 2009 | Ricoh Aficio 1018D Copier
When I try to slide my phone open to type the display skews at an angle and becomes unreadable. If I close it back, part of the screen will go white. sometimes the top and bottom go white, but you can...
Maybe a magnet has come loose in the handset, Or you have exposed it to a magnet. Or there is a loose conection when you slide the handset. Either way you will need a new display
Oct 10, 2009 | Motorola Mobility Rival A455 Cell Phone
Blank display
You seem to have a issue with the Flex Ribbon Inside. The Display has a Flex ribbon that connects to the keypad area. there seems to be a fault with that ribbon. this is common problem with **** shell phones/ Slider phones.. best solution would be to take it to a repair shop. unless you have warranty.
Mar 24, 2009 | Motorola Mobility RAZR2 V8 Cellular Phone
Nokia 6288 screen problem
if you can dismantle your phone here is what u do to know.. 1st check if the ribbon its cut,, or been damage and that will be the solution change it, next if it is ok u still have to try new ribbon for it to check sometimes ribbons even if ther's no physical damage still faulty.. and then if u change it and its still the same u've got a problem either in lcd or your display ic, so u have to bring it to d tech. to save money for buying those unwanted parts.
Mar 08, 2009 | Nokia 6288 Cellular Phone
Paper skewing
There should be an access door on the back of the printer. If you open this you can check the rollers to see if they are damaged or have debris on them.
Aug 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Darthreavan's 6288 problem
You can hard reset with "power off - hold 3, green call and * - power on while holding"
Please note this will format all the saved information stored in phone memory.
Jun 16, 2008 | Nokia 6288 Cellular Phone
Nokia 6288 troubles
HI. 1ST U OPEN THE BACK COVER AND REMOVE THE BATTRY > NOW OPEN THE SCREW > PULL THE BACK COVER VERY CAREFULLY PULL UR MOBILE PCB VERY CAREFULLY AND REMOVE THE STRIP CONNECTOR SAME PROCEDURE FOR FRONT SIDE WHEN BOTH SIDES R OPEN THEN CLOSE SLID AND PULL THE STRIP FROM MOBILE'S SLIDE. THEN NEW STRIP ENTER THE SLID AND FLOWS THE SAME PROCEDURE IN REVERS CONDITION. NOTE -(WHEN U PULLED THE STRIP THEN MIND IT WHICH SIDE IS DISPLAY SIDE OR WHICH SIDE IS PCB SIDE.
Feb 20, 2008 | Nokia 6288 Cellular Phone
Blank screen
there is problem with ribbon of ur phone, ribbon is that parts which connects ur slider part of phone to the lower part of ur phone. ribbon might be damaged. take it technician for replacing it with new one, once it will get replaced u will be able to see ur screen working.
Jan 13, 2008 | Samsung T809 Cellular Phone
Nokia 6288 Cellular Phone Logo
396 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
