PC can't recognize even though it is plug and play
Trying a plug and play Iomega Hi Speed USB2 500 GB Ext Hard Drive, but my PC does not bring it up so I can transfer files etc
  • Frank  Fernandez
    Frank Fernandez May 11, 2010
    Are you looking for the Hard Drive in "My Computer"?
  • mrninja
    mrninja May 11, 2010
    make sure your usb ports are enabled in the bios
    Problem Solver:
  • 6 Answers
have you check the short clip for primary slave or primary master etc..,arrange the sequence they may be have on thesame path,then configure this to your bios set up which is ist priority ,2nd priority. then exit and save.start your windows have a nice day
Posted on Apr 17, 2009
320GB Hi-Speed USB 2.0 Silver Edition Desktop Hard Drive
Some usb drives - i.e pen drives - bring up the same message when they are inserted into a usb port. Windows usually installs the necessary software from within your computer. Other pen-drives are plug and play. Much depends on the operating system you have and the age of the usb pen.
It's probably just a question of getting updated drivers for your desktop hard drive. Right-click on the 'my computer' icon. Choose 'properties' Then choose 'device manager' or 'hardware'. Locate where your desktop hard drive is listed and open it. Then choose 'update driver'. Your computer should then search itself for updated drivers (which it won't find..) but it should also ask you if it can access the internet to search for drivers.
Alternatively, go to a website where you can download drivers yourself. Try http://www.iomega.com/support/documents/10425.html
Be aware that your desktop hard drive is now quite old. It won't last forever .. If you've got important stuff on it consider buying a new desktop hard drive and transferring everything to the new one.
Jun 07, 2013 | SimpleTech 320GB SimpleDrive External by...
My computer is not recognizing the drive when I plug it in.
Hi did you try in other computer if yes and still didnt work do you listen any noise on the hard drive .
another thing to do to be sure that the usb ports are working fine in your computer its not been disabled bu bios or an antivirus please plug a flash drive or other hard drive in the computer and see if it gets recognized if yes then your system dosent have any issue .and check the hard drive if it dosent get recognized in the other computer also then may be the partitiontable is corrupt or your iomega hard drive case has problem.
To remove data from your hard drive in the worse case u need to remove the hard drive and plug it to the system directly and check
Thanks
Dec 04, 2010 | Iomega (33090) 250 GB Hard Drive
Have only just decided to install my new Iomega 500 GB usb 2.0 hard drive and I have mislaid my quick install guide. I have an Apple imac can you help please
Just connect the AC power to the IOMEGA, and the USB cable between the IOMEGA and a USB port on your computer. It is a "plug-and-play" device, and so Apple OS X should automatically recognize it.
Nov 21, 2010 | Iomega Prestige 500 GB USB 20 Hard Drive
Desktop cannot read/detect iomega even though on and connected - what can be done to restore proper interaction between Iomega External Drive and my Desktop?
this is in April...so make sure all connection are connected...go to start/all programs/accessories/system tools/system restore...(you are going restore your pc to an early date when it was working properly)...next...choose March 04, 2010..your system will cut off and restart you must click ok when prompt to do so when booting back up
Apr 04, 2010 | Iomega MiniMax Desktop - Hard drive - 500...
I unplug my exernal drive with out safely removing it and now it doesn't do anything
for one plug and play devices don't need to be any way to remove
they are plug and play , check the USB port try another port
check drive listen can you hear it moving ? and what operating system are you using ?
Jan 11, 2010 | Iomega MiniMax Desktop - Hard drive - 500...
My iomega 500gb external hd isn't being recognized. There's an icon for safely removing hardware but under the 'my computer' tab there's no icon for the drive, as though its not even there. It had been...
Did you have to install a driver for it initially? Try reinstalling the driver, if so.
I thought most drives were plug and play. If it does not have a driver, trying using a different USB port. Sometimes the ports can freak out and not recognize the item plugged in, especially if you use multiple items in the same port. (ie, cameras, cell phones, printers, etc)
Hope this helps at least some. Good luck!
Jul 31, 2009 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
No manual for 320 GB desk top hard drive
its a plug and play just connect to the sys and start working on it
but be careful that u connect the power to the Ext.HDD first and then after that connect it to the USB port
similarly safe remove from the Sys and remove it only after u see the msg It is safe to remove the USB drive disconnect the USB cable from the Sys wait for 20-30 secs ten power off the HDD for better performence of the Ext HDD
Jul 27, 2009 | Electronics - Others
Iomega 250 GB external stopped working
This is really not a solution, but you should all try to connect your iomega to a imac, and use the Disk Utility (in Utilities folder), if you have any luck the hard drive will be recognized and you will be able to format it
Dec 18, 2008 | Iomega (33215) 250 GB Hard Drive
The drive not reading
Hi, Chinmay
                      You have to look into first all of  drive's externale power adopter , and then after usb controller cheap beacuse controller is the media of communication between usb protocol and ide protocol
Oct 14, 2007 | Iomega (33222) 80 GB Hard Drive
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
