Question about Dishwashers
Standing water at end of cycle
Standing water in bottom of tub after cycle is finished washing and drying
  • Anonymous May 14, 2009
    I have a similar problem; after my dishwasher has completed it's cycle, there is 1-2" of water in the bottom.
  • 423 Answers
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Posted on Apr 18, 2009
GE Topload Washer WPSR3100W1WW -- finished spin cycle, clothes were spun as normal. Water on the floor after spin cycle. When jiggling tubs, we can hear there is some water still in machine. Bottom metal...
That is normal. The balance ring has liquid in it. # 327
On these machines the tub is suspended with 4 metal rods. The lateral movement is controls by 4 straps. When these stretch the tub gets loose and water slings out the washer. Seen it.
Training Manual
This video shows how to take the whole thang apart:
Sep 18, 2010 | Washing Machines
Have an affintiy front loader that wont do its final spin. Passes all the diagnostic tests that comes with the machine but when timer goes from 6 min left it just shuts off and gives the end of cycle...
there may be something blocking the drain pump.if you have standing water in the tub use a wet dry shop vac and attach it to the end of the drain hose to remove the water.
once you remove the water check the drain pump for obstruction the main drain boot the comes from the bottom of the tub to the pump make sure everything is clear.
If you do not find anything then there is a chance that the door lock mechanism is faulty
Jun 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Standing water in washer after cycle
take off the bottom front panel and clean the coin trap it will be up front just unscrew it have some towels handy
Dec 20, 2008 | Whirlpool GHW9400 Front Load Washer
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Wont finish washing cycle
suspect not draining. if not then problem could be the filter. at back, remove the small panel at the bottom. you will see a hose from the bottom of the tub to the pump. remove this hose at the tub end and the filter is inside.be carefull, if machine has not drained, a lot of water will come out. disconnect from mains of course
Jun 13, 2007 | Hotpoint Ultima WF860 Front Load Washer
Dishwashers Logo
365 people viewed this question
Top Dishwashers Experts
