Question about Sharp AL-1642CS Copier
Our Sharp AL-1642cs printer prints very faintly and have now replaced the drum and toner with no results. Have spent hours on this and the unit is not very old. Any ideas?
  • pegasus2972 Apr 17, 2009
    Thank you - great advice. Apparently didn't need the new toner and drum......
    Sniper:
  • 54 Answers
Open the right side door and carefully clean the transfer wire with alcohol on a paper towel.
Posted on Apr 17, 2009
SHARP AL-1642CS : Printing lines from side to side every few inches :(:(:( There is plenty of toner . I purchased the machine used, and prior owner claimed it was used very little. Any thoughts ?
The prior owner may have used the machine just sufficiently to observe that the drum needs replacement. Drum replacements can cost more than the machine is worth
Aug 02, 2013 | Sharp Office Equipment & Supplies
On line button on copier
it must be shared for all to access. The online button can be pressed to stop the print process when adding paper or toner.
Feb 17, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
I replaced the Sharp AL-1642CS TD toner cartridges twice. Still flashes the toner symbol. Someone mentioned cleaning the toner sensor. Where is the toner senor located? drjanisch
Where the toner bottle inserts into the holder, make sure the OLD bottles nipple is not stuck in there, this issue will not allow the new toner to flow into the system and the machine thinks it has an empty bottle
Apr 04, 2009 | Sharp AL-1642CS Copier
Getting double images on copies, how can I fix?
It's one of two of these solutions. The fixing rollers more so the upper fixing roller which is the hot rollers at the exit end of the copier is dirty or need replacing. Or the drum has a cleaning blade on it that needs replacing. If you look at the drum and see if toner is still on the drum if so then your cleaning blade needs replacing. Also if that copier uses a blanking lamp then it might not be turning on so you can get double images.
Mar 04, 2009 | Sharp AL-1642CS Copier
Printing problem on Sharp Copier Al 1642CS
it would have spilled toner on the laser unit glass which can be accessed after removing the developer & drum units. Its on the upper part inside the machine in the drum chamber.
Nov 28, 2008 | Sharp AL-1642CS Copier
SHARP AL1642CS prints but very faint
Found that fuser wire had broken.  Sharp wanted $140 + packing +shipping to look at it.  Found that Staples had newer model on sale for $499 minus $250 rebate.  Stripped toner & drum from old machine and bought new one.
Nov 24, 2008 | Sharp AL-1642CS Copier
AL-1642CS
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
Apr 16, 2008 | Sharp AL-1642CS Copier
Sharp al-1551
Did you replace the drum with a Sharp brand drum? I recently replaced a drum in my Sharp AL-1642CS, the replacement drum fits ok, and the lights you describe are gone now, but it does make an annoying noise that is new. I wish I would have spent the money to get a Sharp drum, then you can call them directly for support. When I have called them they have been very helpful.
Dec 14, 2007 | Sharp AL-1551 Laser Printer
103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
