Have a Kenmore 20712990- ck. it will go through the the cycle until it is time to spin, sucks all the water out then it will not spin, it had the motor smoking trying to go, we thought it was the motor, until we put a new one on it same problem but no smoking.
  • 686 Answers
TRY THIS SITE www.repairclinic.com ENTER MODEL NUMBER AND SCROLL DOWN ALL THE WAY CLICK THE RED 100 AND SEE ALL PARTS. CHECK 1195967 2670 2690 AND 1254. THIS IS EASY TO WORK ON BUT IF YOU DO NEED TO REMOVE THE TRANSMISSION FOR CLUTCH OR BRAKE REPAIRS YOU'LL NEED TO REMOVE THE NUT UNDER THE FAB CUP AND CAP ON AGITATOR PULL AGITATOR OUT
Posted on Apr 17, 2009
Kenmore washing machine model 20712990 wont spin
If you don't hear a click when you close lid, replace lid switch. If when in spin, you hear motor but does not spin, replace motor coupler.
Sep 02, 2014 | Kenmore Washing Machines
Kenmore washer 110 20712990 won't spin
You will need to replace the lid switch. Here is the part to order.
Below is a video to show you how to replace the switch.
Nov 17, 2012 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore 800 series washer that won't fill with water, but will go thru the spin cycles if you set it manually, was working fine before except I thought it was using too much water on the auto...
this could be a pressure sw . too ck remove the air tube and blow on the sw it should click . or use a ohm meter to ck it it has 3 wires going to is power in ond power out to valve when it gets full of water it shuts of water and turns on motor .. . the spin does not have anything to with fill & wash . but it does help for the diag of mach ( thanks ) hope this has helped mm feed back pls ..
Nov 08, 2010 | Kenmore 24032\24036 Top Load Washer
Washer won't drain..like filter is clogged
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
Mar 27, 2010 | Kenmore Elite 21082
Please help!
remove bottom panel remove as much water as possible from tub ..have lots of towels handy remove clean out port on pump clean and reinstall...also ck as far into pump for something jammed in impeller ..pump may need to be removed to clean if unable to clear jam ..3 screws hold pump motor to pump body remove if necessary also ck to see if pump impeller is spinning freely on motor shaft should be some resistance when turning if impeller spins freely replace pump
Oct 04, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore model # 110.20722990
ck all motor connections just lean washer back against wall motor is right at front if motor ckd ok 2 things left motor or timer neither one is cheap but best guess would be timer
Sep 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series
you can look at the water pump inlet and outlet hoses. sometimes socks and other small items would be sucked in and blocked the water from going out.
another theory would be the clutch on the spin cycle is slipping that is why the drum is not spinning as fast as it should.
tnx 4 using fixya,
drcool
Sep 02, 2008 | Kenmore 15864/15862 Top Load Washer
SEARS/KENMORE MODEL 110 WASHER
if you are using a rubber drain hose look for a kink for flattened area this could be restricting flow out of washer replace hose with the plastic hose that comes with it..also ck hoses and pump for restriction ( socks ,thongs) lastly remove pump and ck impeller for severe wear impeller should be almost same diameter as pump case if it's a lot less replace pump
Aug 29, 2008 | Kenmore 24032\24036 Top Load Washer
Calypso kenmore washer won't spin enough water out during cycle...error displays SL
ck pump for lint /obstruction blocking impeller ..lean washer back remove pump bottom 4 screws if new style old style remove hoses and ck
Jul 21, 2008 | Washing Machines
Washing Machines Logo
329 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
