Question about Toshiba TP43H60 43" Television
No picture, sound and flashing red power light...
Our Toshiba TP43H60 was working one evening. I got up the next morning, tried to turn it on and: We have a flashing red power light and no picture, no sound, nothing. It was working last night...any ideas? What I have read so far about these projection TVs makes me wonder if it is just a fuse; are these easy to change? What else would cause this? Thanking all in advance.
  • 2 more comments
  • kct0 Sep 23, 2007
    We had no problems with it prior to this happening; it's a total mystery to us. It was, literally, working perfectly the night before then nothing when I tried to turn it on the next morning.
  • pattywest13 Dec 31, 2007
    same problem...TV was fine..then no sound , no picture, flashing red light and clicking sound when attempting to turn on..black screen.
    Unable to do anything to resolve problem so far.
  • marin13 Mar 16, 2009
    I have a Toshiba projection tv. It was fine until I had cable connected to it. The very next day, the tv won't turn on and the power button just blinks a red light. Does anyone have any ideas whats wrong with it?
  • Anonymous Apr 14, 2009
    no prende flashing red power light
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Posted on May 18, 2009
Flyback transformer xtk3135
Posted on Nov 01, 2007
    Genius:
  • 1,153 Answers
What type of problems you had before set went out? If color problems then maybe your convergence amps gone. If sound problems then look at the audio areas, If vertical then vertical output.
Posted on Sep 17, 2007
SOURCE:
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
Excellent picture for a several hours, then gradually dims.
if this is a old unit the there is serious problem with the display.
check how many times the light blinks and get back to us.
Feb 08, 2009 | Toshiba TP43H60 43" Television
I have a TP43H60 toshiba and the power light continues to blink red and there is no picture or sound. I can't turn it off either unless I unplug it??
You have blown one of the pecos fuses, probably the f850 or f852, you can test them with the power unpluggrd and with an ohm meter. Replace them with only the recommended amps fuse. Your set is going into standby, because of the blown fuse.
Jan 28, 2009 | Toshiba TP43H60 43" Television
Toshiba big screen tv. tp43h60
Good Day;
I would suspect the convergence IC's, to confirm this unplug the convergence yoke, all three. If TV comes on IC's are bad. Also, check the little green pico fuses. Good Luck, big IRISH.
Nov 10, 2008 | Toshiba TP43H60 43" Television
No picture, No sound
If the set is a TP43H60 like the posting says it is I show it as a CRT based Projection. And this one does not have a lamp in it. So if you could verifiy the model number
Feb 20, 2008 | Toshiba TP43H60 43" Television
Toshiba TP43H60
You need to trouble shoot your power supply. There is a toshiba power supply and shutdown circuit troubleshooter available for your model at the following link for 10.99 They will also provide free unlimited assistance after you purchase a manual. They will either mail it or email it. If you'd like it emailed you must return to the site after purchase and click on the contact link and request that they email it along with the info on how to obtain the free support. just provide the email address you want it sent to. Hers the link. http://servicemanuals.vstore.ca/
Dec 31, 2007 | Toshiba TP43H60 43" Television
Toshiba TP43H60
I have the same issue with my toshiba 32" circa 2000. I am told that it is a burned out diode of some sort and it is a horrendous repair job.
Aug 27, 2007 | Toshiba TP43H60 43" Television
Toshiba tp43h60
You have a bad regulator IC or something in the seweep power supply is blow out. if you can read a schematic, i suggest you get one to troubleshoot the solid state circuits in this TV set. if you do not have any solid state repair experience or no electronic background, play it safe and call in a pro to assist you in the repair of this TV set. Good Luck.
Mar 17, 2007 | Toshiba TP43H60 43" Television
Toshiba TP43H60 43" Television Logo
748 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
