Question about Whirlpool Dryers
Gas dryer heats up at start but after a while heat shuts off
Heat
  • Michael Masters
    Michael Masters May 11, 2010
    your description of the actual problem was cut off. can you elaborate on this issue a bit more please??
  • 659 Answers
You need to clean out your vent. Also, pull the dryer out and clean from the rear of the unit all the way inside as well. If the unit can't "breath", it will shut down the unit on thermal lockout. Until it cools, it will not start back up. It can trip a limit switch that you might have to reset and it is located near the burner assembly.
Posted on Apr 17, 2009
Why does my gas dryer heat keep shutting off?
The solenoid coils on the dryer are acting up. This is a common problem. They work a little then heat up and short out. Easy fix I did some videos:
How it works
Replacement
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 22, 2012 | Maytag Centennial 7.0 Cu. Ft. Super...
The gas dryer heats then does not heat. The sensor says 99 minutes to dry close. Tried it on timed heat and it dries then stops drying. Sometimes shutting off completely!
Hello,Cheack to make sure your venting is clean and clear..If its blocked the safty thermostat will shut the heat down to prevent overheating.. If the vent is clean i would check the coils.When they start to fail it will heat then not cycle back on..
Jun 18, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Our kenmore gas dryer is starting but after 1 minute the heat shuts off what could it be
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101/,./'
Mar 27, 2011 | Kenmore 600 6965 Electric Dryer
Heat starts and runs for a short time than gas shuts off
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 27, 2010 | Roper RGX4634KQ Gas Dryer
Kenmore 70 series dryer starts and heats up then shuts off
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 02, 2010 | Kenmore 73952 Gas Dryer
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
The heat in my gas dryer does not stay on. What
heatman101
Mar 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
When I start the dryer in either auto or timer mode the burner starts and the heat comes on. It will run for awhile with heat and then the burner will shut off. The dryer continues to spin but no heat is...
With the limited information you gave I will assume this is a gas dryer that the flame starts for a minute or so and then shuts off. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Oct 06, 2009 | Whirlpool LGR3624JQ Gas Dryer
Start gas dryer heat will ignite after a couple minutes no heat
That is usually a sign that the gas solenoids are weakening. Sometimes for some dryers you can buy a pair. Don't know your complete model number.Thanks, Sea Breeze (Visit my site)
http://servicepartstec.blogspot.com/
Mar 23, 2009 | Kenmore Dryers
Dryers Logo
48 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
