Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
KUDI01TJWH0 kitchen aid....the clean light is blinking and wont do anything else....how do we reset or do we just need to take it in for repair?????
  • mthoma5 Apr 27, 2009
    Did you ever receive a resonse on this? My clean light is blinking and needs to be reset with diagnostics. How do you do it?
  • Anonymous Apr 27, 2009
    I dont seem to have a "dry heat" button on the washer
I have a kitchen aid 24" built in dishwasher that will not run and the clean light just keeps on blinking
Posted on Nov 20, 2009
  • 3 Answers
To invoke the diagnostic cycle, perform the following key presses in less than 6 seconds while in standby.
Heated Dry -> Normal -> Heated Dry -> Normal
Invoking the diagnostic cycle clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle. (quoted from service diagnostic cycle notes in troubleshooting guide)
Posted on Apr 27, 2009
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
HOW TO RESET THE CONTROL PANEL ON KUDE60HXSS4
My Kitchen Aide Dishwasher KUDE60HXSS4 has the clean light blinking and water is coming out of the dishwasher running down the back wall. The dishwasher will not come on. The clean light just blinks.
Jul 11, 2012 | KitchenAid Architect® KUDT03FT 24 in...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Kitchen aid dishwasher with blinking lights. Manual says to call service tech.
and so you did / im a service tec . need more info th help . like mod and ( kitchen -aid ) . try looking in the front toe panel for a tec sheet this will tell you about the blinking lights and what the mean . get back with me if you need more help //mm fed back pls .
Dec 17, 2009 | Refrigerators
Kitchen aid oven blackout after using self clean. Waiting for repair. $100.00 service call. $ 70 part fee. From what I read on the internet this will just happen again. Anyone know of a way to solve this...
this is probably the thermal fuse replacement fix (see my other posts for easy replacement directions)..
i'm sure kitchen aid wont recommend this but if you slip a thin piece of cardboard or non combustable insulation material between your replacement thermal fuse and the oven wall, you may not have the problem again..
good luck
tpug
p.s. i'm trying to source an auto-resetting thermal fuse for this application... if i find one, i'll post knowledge for everyone..
Jul 15, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
1,634 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
