Screen controls Hi, I have an LG W65 laptop, how do I adjust the screen brightness and contrast ? Thanks.
  • 1 more comment
  • Anonymous May 02, 2009
    The laptop seems to be in sleep mode. The screen is dark and I can't brighten it. It makes it very hard to view videos and certain pages.
  • Anonymous May 10, 2009
    my screen iss to bright
  • ERIC BAKER May 11, 2010
    Have you tries pressing the Fn key and the arrrow key's to the lower right of the keyboard?
Contrast
hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu?
thanks
Apr 02, 2014 | Sony VAIO Computers & Internet
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Contrast is way too bright, not screen brightness, contrast. is there a contrast adjust button?
Right click on your main screen. Go to properties, or graphic properties, then you will find there is a contrast adjustment within. Usually under color correction.
Mar 24, 2011 | Toshiba Portege 4000 Notebook
Can you adjust the screen brightness to brighter? ACER ASPIRE ONE?
Hello. yes. to adjust the screen brightness, go into the control panel and find the brightness or contrast adjustment. Joe
please rate my answer as 4 thumbs up. thanks.
Oct 02, 2010 | Acer Aspire One PC Notebook
How do I adjust my contrast of my screen the brightness not a problem.
Hi, to start; click on the "Start Button, in the (Start Search) window type: power, this will bring up the next window where you be able to make adjustments to the "brightness / contrast. "Rating the solution on its helpfulness is appreciated, thanks."
May 13, 2010 | Sony VAIO VGN-FW140E/W Laptop
Acer Aspire 5630 screen brightness adjustment...
How do I adjust my brightness or contrast on my laptop? See our brightness definition for a visual example. Finally, most laptops only enable users to adjust their brightness of their screen.
Click on the above Link, Good Luck, Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Aspire 5100 Notebook
Computers & Internet Logo
370 people viewed this question
David Payne
David Payne
