Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi there my Belin N1 works fine from my laptop but not from the PC. The Belkin Support centre advised the USB port needed upgrading and they could not help further... Can you assist?
  • 3 more comments
  • Bethka Sep 16, 2007
    Hi there
    We have tried all USB ports, interestingly when we put into the usb combo, it recognises for the first 15 secs (ie lights up as connected on the USB comboo) then goes off and the PC delivers a message saying USB device not recognised.
    The only USB port I can see if it is 2.0 is for the combo and it is 2.0.
    The PC model is: AMD Athlon (tm) XP 2000+ 1.67GHz 512 mB of RAM
    The OS is Windows XP
    We have been trying both hub and port.
    Thanks for you help
    Beth
  • Bethka Sep 17, 2007
    Thanks for your ongoing help :-)
    I have uninstalled the driver and then reinstalled.
    It asks for you to insert the USB Network Adaptor and which ever USB port I put in it say:
    USB Network Adaptor is not found. Insert your USB Network Adapter to activate the driver. Click OK to continue.
    Then I click OK and I was asked to reboot which I did.
    Then when I click on the Belkin icon on the desktop it does not open at all.
    I just downloaded the beta update driver and this now allows me to open the wireless Networking Utility. however the adaptor is not picking up wireless.
    For info (,ay not be relevant) in device manager it seems Belkin is showing as Unknown evice under USB Controller list. It keep s trying to refresh the list. (When I remove the Belkin USB Unknown edvice no longer displays) Then when I look at the properties (for unknown device) it sayd No Drivers are installed with this device)
    Can you let me know how to get details on the motherboard. I think the PC was assembled in 2002-3.
    More for info (may not be relevant!) the Generic USB Hub Location says USB 2.0 Hub) All the others say Location 0
    Yes we have Service Pack 2 XP is version 2002.
    Thanks for your help
    Beth
    Hi again, you are being a star.
    Okay to answer your questions:
    >> I tried to run the Wireless Zero Configuration but when I get to the General Screen of properties on the Service Status tab, ther Start button is not able to be clicked (greyed out)
    >> I downloaded the beta drivers on my laptop and then burnt to CD and loaded from there.
    >> WHen I plug in the adaptor it does not list under the network adapters here but does uner USB controllers list
    >> Motherboard
    (c) American Megatrends Inc.,
    62-0710-009999-00101111-040201-VIA_K7-1AARK204-
    Maybe we'll work this out hey.
    Thanks again
    Beth
  • Bethka Sep 21, 2007
    Hi again,
    Apologies for the delay I was away with work and only just got back to try all of this.
    >>When it got to the point in the please plug in your USB Network adapter now, it din't recognise the Belkin USB still. And again Unknown device is showing under USB list in device manager.
    Re motherboard
    When I pause/break the relevant information never comes up. There is the number I said before an the following information:
    American Megatrends Released 07/10/2002
    AMIBIOS (c) 2001 American Megatrends Inc
    A6380vMS v5.5 071002
    AMD Athlon (tm) Processor, 1250 MHz
    Thanks again for your ongoing help
    Beth
    Hi there, we have just gone and bout a new PSI 2.0 USB port
    All works fine now, so it cost £20 more but at least we are there now.
    Thank you so much for all your hard work
    Kindest Regards
    Bethx
Hi All
I use a belkin N1 modem/router and usb adaptor and it was a problem child with drop-outs, on Vista HP. It now performs much better, since switching security to WEP 128 bit. I'd use higher security but one wireless card can't handle it.
Incidentally, the Belkin performs well on non-Belkin G level cards.
Cheers
NOEL GORDON
Posted on Jan 10, 2008
    Brigadier General:
  • 6,966 Answers
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Posted on Sep 16, 2007
  • 2 more comments
  • Louie  Role
    Louie Role Sep 17, 2007
    Hi again Beth,
    I have to ask, were the drivers installed on the desktop PC too?
    If they were, perhaps you can try and uninstalling them. Thereafter, reinstall and follow closely the installation procedures. There are some models that require that you do not plug in the USB Wireless Adapter not until the installation requires you too. The procedure may also ask you to reboot. In some cases, Windows will report that your driver/installer files has not passed Windows testing, just click on "Yes" or continue.
    If that doesn't work, power down and reboot with the USB Wireless Adapter plug into a port.
    If you need copy of the driver/manual, it is available online at "http://www.belkin.com/support/".
    If still a no joy, pls post back with any messages from Windows. Also your motherboard brand/model, something like Asus A7S333 or ECS K7S5A (normally shown after power on before Windows start).
    Cheers.
  • Louie  Role
    P.S.
    The info on the motherboard brand/model would give us:
    1. info on USB features. There might be known issues, patches, update for your motherboard;
    2. "AMD Athlon (tm) XP 2000+ 1.67GHz" suggests that the desktop was assembled in 2002-2003 where USB 1.0 was still the norm and 2.0 was just coming up;
    Another query is have you installed SP2 to your XP?
  • Louie  Role
    Re your last post:
    "...beta update driver...open the wireless Networking Utility...adapter ...not picking up wireless..."
    hmmm, this has something to do with Windows Wireless Config - On WinXp, let's check if your Wireless Config is Enabled:
    1.To access this service, you can navigate to the Control Panel, then Administrative Tools and finally double-click on Services**.
    2.From the services window you will want to scroll to Wireless Zero Configuration and right-click on it, then click Properties.
    3.From the Service Status area choose Start to start the service.
    4.From the Startup Type drop-down menu, choose Automatic so that the service starts up the next time you start Windows XP.
    5.Alternatively, you can launch Windows Run, type services.msc and click OK.
    May I ask how you downloaded to the desktop the beta drivers?
    "...in device manager...Belkin...Unknown device under USB..."
    Should not be under USB but rather Networking adapters.
    "...properties (for unknown device)...No Drivers...installed..."
    Try right click and "Update Driver", No, not this time, Install the software automatically.
    "...motherboard details..."After powering up during POST (first group of characters & numbers), press Pause/Break, copy the group of char & #s at the bottom of the screen (something like 4/03/2003-P4X266E-8235-6A6LWJ19C-00). Press "Esc" to continue booting.
    "...Generic USB...USB 2.0 Hub..."
    Understand, I expected it to be so since you have SP2.
    Looking forward to your motherboard details.
  • Louie  Role
    Louie Role Sep 18, 2007
    Re the motherboard. Based on the info you gave me, the possibility is a Microstar MS-6380E Pro. There are several versions of this motherboard:
    KT3 Ultra/ Ultra-ARU
    ? KT3 Ultra (Standard Version)
    ? KT3 Ultra-ARU (ATA133 RAID, USB 2.0(NEC))
    KT3 Ultra2
    ? KT3 Ultra2 (Standard Version)
    ? KT3 Ultra2-R (ATA133 RAID)
    ? KT3 Ultra2-BR (ATA133 RAID, Bluetooth ready)
    KT3 Ultra2-C
    ? KT3 Ultra2-C (Standard Version)
    ? KT3 Ultra2-CL (Onboard 10/100 LAN)
    One of the original BIOS was in 2002-02-28 version 5.1; one of the latest BIOS is 2003-02-24 version 5.7. There are a total 7 versions/revisions. Of course, presumably the best would be the latest. The BIOS would be dealt with following your response to exact model of motherboard
    Pls find out the exact model, version number and date by doing the Pause/Break again. It normally is shown on the 3rd or 4th row/line of the screen/display where you saw the "62-0710-009999..."
    In the meantime, pls try the following:
    1. Powerup the desktop, boot to Windows, go to Device Manager and uninstall the Belkin or Unknown Device. Likewise uninstall all the USB instances (USB Hub, Host Controller, Composite Device, Root Hub & everything under the USB);
    2. Do not reboot;
    3. Go to Start, Run, type "regedit";
    4. In Regedit, click on File, Export, in File Name, pls type "001", "Save", it will take a moment to backup/save your registry in file 001.reg. then click on Edit, Find, in the Find windows type "Belkin", click on Find Next;
    5. Every time a Belkin entry is found press "Del", click on Yes. After every deletion, press F3, and repeat process. Repeat till Windows says "Finished searching through the registry." The idea is to completely remove any Belkin info/entry in your PC. This way we will be assured of a clean/fresh install and hopefully no conflicts.
    6. Reboot the PC. Press "Del" to enter the BIOS/CMOS setup. Arrow down/right to "Load BIOS Setup Defaults, "Y", enter, press"Esc" once;
    7. Arrow down to "Integrated Peripherals", Enter, Verify/Make "USB Controller" - "All USB Port"; "USB Legacy Support: - "Enabled", press "Esc";
    8. Arrow down/right "Save & Exit Setup", Enter, "Y", Enter, system will reboot;
    9. Ensure that no USB devices are plugged in including the Belkin;
    10. After booting, Windows will auto detect the USB ports, allow it to install all necessary drivers. This may take a little time. Verify that the USB ports are reinstalled and no problems in the Device Manager. Reboot;
    11. If you have other USB devices (other than the Belkin), plug them in and check if working as before.
    12. If no other problem, reinstall the Belkin. Load/install the drivers and go thru the process. When asked to plugin the Belkin do so but If it came with a mini-cradle and extensions USB cable, use that instead of directly connecting. it is preferable to use the USB port at the rear of the PC.
    Copy the "Thanks" and welcome, but we are not out of the woods yet. Your patience and determination is noteworthy.
Inttalled belkin wireless adaptor, says strength is good, but not valid ip
the work of a belkin adapter is to receive the wireless signal in and around the adapter when pluged into computer
if ur able to see the wireless network then ur adapter is working fine
check the ip as
start>control panel>network connection>rite click on wireless network>click properties>choose internet protocol tcp/ip (highlight it and click on properties) then "obtain ip address has to be checked"
then cllick OK and try going online --- u must access the internet
Feb 20, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
I need to download programme for belkin wireless g usb network adaptor installation
Find the Version Number on the Adapter
Goto
http://en-us-support.belkin.com/app/answers/detail/a_id/2752/kw/F6D4050/r_id/166
Download the appropriate driver
Let me know if it works
Nov 17, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
Linksys router and Belkin wireless adaptor
Anne ,
I need to ask is the driver for wireless adaptor installed ?
Thank you ,
Styme = )
Jul 28, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer http://www.wi-fiplanet.com/reviews/article.php/3645166 if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N1 Wireless not STAYING connected
change channels to 1-6-or 11. Make sure you change all of them.
Jan 07, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Wireless USB adaptor not found
Hi zlyman, The Belkin N1 Wireless USB 2.0 Network Adapter might be choosy with what motherboard it is attached to. Pls refer to this similar problem > http://www.fixya.com/support/t201253-not_identify_belkin_n1_wireless_usb Hope this be of some help/idea. Post back how things stand or should you need further information. Good luck and kind regards.
Oct 02, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N1 Wireless Adaptor not connecting on PC
what the adviser meant was your pc cannot provide enough power to the usb port to power the unit, assuming you have tried other ports and it still wont work; you will need to either purchase a pci usb 2.0 card adapter or purchase a mains powered usb hub and connect to this instead.
Sep 15, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
721 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
