Question about Dishwashers
Water stay in . - Dishwashers
  • 423 Answers
Please post back here what the manufacturer and model number of your dishwasher.
Also, approximately how many years old is your dishwasher?
Can you be more specific with your problem?
If water remains after the cycle is done:
Is the water clear/clean?
How much water is left? More then 2 inches?
Please post back here with your findings, OK?
Posted on Apr 18, 2009
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
Sep 04, 2013 | RTO W4 A.O Smith Gas Hot Water Heater...
My water heater control won't stay on. I have to
Sounds like the thremostat is going bad and not functioning right thats why you reseting it so much and then it works. They are not to expensive to replace just write down info of water heater or take old one with you to store
May 04, 2010 | White Rodgers 0754-1 Electric Water Heater...
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Water feed stays on 24 volts stays on
Your humidistat is probably stuck closed. It may need replacement.
Nov 02, 2009 | Aprilaire 400 Humidifier
Atwood water heater light doesnt stay on
That light in the switch should only be on momentarily while it is igniting, and then go out when everything is ok. If light stays on, it's to alert you that for some reason, the burner did not ignite, such as propane is off, or some other reason it didn't ignite. If the light stay out, then the burner should be working properly.
Oct 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
Dishwashers Logo
97 people viewed this question
Top Dishwashers Experts
Owen Barnes
