Question about Epson Stylus CX5400 All-In-One InkJet Printer
Scanner error - Epson Stylus CX5400 All-In-One InkJet Printer
  • Epson Master
  • 691 Answers
When you switch it on, does the scanner try to move? If it does but cannot, is there a locking mechanism that you have forgotten to unlock? If not, in most cases the head is stuck. You can try to dismantle it and move the head by hand to half way down the track. Then reassemble and see how it behaves. If it then returns home and stick in the same place, there may be a problem with the track. Use some PTFE lube to (very sparingly) to grease the track. If it still sticks then there is another physical problem which may mean the scanner unit needs replacing. you can get a service manual to help you dismantle it from http://www.TheServiceManualShop.com
Posted on Sep 16, 2007
  • Inky Fingers
    Inky Fingers Sep 16, 2007
    If you dismantle the scanner make sure you do it in a VERY CLEAN environment. Any dust or fingerprints will leave marks on all your scans.
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
How to fix scanner error 6?
herewith 3 suggestions (try searching the HP forum or search engine 'scanner error 6'). Read all of them before you decide to do anything and only then decide which order if any to do them depending on ease vs likely effectiveness.
HP LaserJet 3055 Scanner Error 6
HP Laserjet 3055 Scanner Error 6
6.July.2015
Jul 06, 2015 | HP LaserJet 3052 All-In-One Printer
Engine scanner error (internal hardware laser scanner error) error message laser scanner
This means that the laser unit inside your printer has failed. It costs around 100 dollars for the part and it needs to be installed by a trained technician. Best idea is to buy another printer. Sorry.
Sep 29, 2013 | HP Laserjet P1505 Printer, Remanufactured,...
Scanner Error - Power On Power Off
The "scanner warming up" error is usually caused by dirty glass or mirrors in the scanner assembly. Here is a link to a step by step guide that tells how to open the scanner unit and clean the optics to clear the error.
http://www.ccl-la.com/blog/index.php/hp-laserjet-3330-scanner-warming-up-error/
Feb 28, 2013 | HP LaserJet 3300 All-In-One Printer
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
Hp laserjet 3055 has code 52 scanner error and wont print or copy
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
Jan 15, 2010 | HP LaserJet 3055 All-In-One Printer
HP 1005 Scanner error 6
dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
please if you can help me
Sep 07, 2009 | HP LaserJet M1005 Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Error 201
Which scanner is this? Error (201) usually indicates some sort of power issue...such as the scanner is not getting enough power. If this is a USB powered scanner you may try connecting to different USB ports on the computer.
Mar 28, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Epson Stylus CX5400 All-In-One InkJet Printer Logo
396 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
