Question about RCA RS2652 Shelf System
I buy RCA #RS 2764 shelf stereos to sell. Several have problems like:wont read the cd so wont play it;some have no power at all;other units wont open or close cd changer
alexhor
  • 28 Answers
SOURCE: Rca 5cd changer tray
first basic step if u still haven't tried this yet is to turn the power button off then unplug the appliance then plug it again and turn the on the power button for the compact disc unit to initialized its program on its CPU and memory devices.
second step: if you can manage to open u'r mini component, check the mechanical moving parts of cd rack if there's any broken parts or missing parts.
third; if you still have the remote control try using it.
4rth; don't forcibly close it manually it will just worsen the problem. hope this tips help ;-)
Posted on May 24, 2009
Zong_Tech
  • 37 Answers
SOURCE: Rca rs 2657 cd changer will not play. Only makes a
Cd tray Moter is broken
Posted on Sep 20, 2009
  • 3 Answers
SOURCE: my rca rs 2657 cd changer is stuck. door will not
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Posted on Oct 17, 2009
Testimonial: "A motor is running when i hit the door open button. A humming loud noise. Will take apart and explore and keep u posted . thanks"
SOURCE: my rca rs 1289 5- cd changer mini system will not
Remove the case screws on the left and right side panels. Pay attention to the long screws that come out of the middle of the panels to make sure they get back in the right spot. Remove one screw from the top rear back panel. Lift side panels of in a hinged motion from the bottom. Remove the top panel in a hinged motion from the rear. In the center of the disc tray remove 1 screw from center. Note the orientation of the tray for re-insertion. Lift the tray up and out. look for small dc motor and spindle. this motor is used to spin the tray. You should find a black belt2_bing.gif between motor and spindle. Make sure it is in good condition. Look to the right rear of the unit. there is a second motor and belt which drives the tray. This belt may be broken or off its spindle. repair or replace the belt as necessary. Plug the unit in and test the open/close function and ensure the gear train, belts2_bing.gif and carriage move smoothly. reassemble.
Posted on Apr 15, 2010
hmerchant110
  • 7191 Answers
SOURCE: I have a RCA rs
You can download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on Sep 05, 2010
RCA RS2664 Stereo wont play CD in any of the trays but seems to try to scan to play.
Hello
The laser pickup unit's lens may be dirty or dusty. Just put a lens cleaning disc into the tray, and play it at least three times, by ejecting the disc each time, and reinsert in in to. The lens cleaning disc can be bought from most of the electronic spare part selling shops at your town, and won't cost more. If it dose not help you, the laser pickup unit of your RCA device should be replaced with same type and number. OK.
Jan 25, 2012 | RCA RS2664 Shelf System
I have a rca rs 2663 stereo, The cd tray will not open or play cd's anymore. Could you please help
It two things can cause this:-
The motor is damaged ( you can listed closely to hear if the door motor runs when you try to open the tray.
Or The belt that takes power from motor to open mechanism is damaged.
Aug 19, 2011 | RCA RS2663 Shelf System
My rca rs 2764 system the cd player wont open
Hi, what makes a CD player not ejecting or not opening is because the Sim tray which carries the CD inside the player when inserted is damaged and it's not performing it suppose to. o weak to function, You will need to replace the Sim tray that allows the CD go in and out...
Have a nice day...
Feb 18, 2011 | RCA Audio Players & Recorders
Rs 1286 rack system,cd tray not working properly,player wont read or play disc (made by rca)
If the radio and cassette work, then your CD lens needs to be cleaned. You can buy a cleaner CD, or you can do a better job by removing the case (MAKE SURE THE POWER IS OFF) and then clean the lens with a Q-Tip and denatured alcohol.
Feb 18, 2011 | RCA RS1286 CD Shelf System
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
RS 2653
I had a rca system similar to this little different. It's a problem you'll find in any cd player after awhile. You'll need to replace the laser. It's quite easy google for some instructions to replace a cd laser. Look around for a laser that can read cd's and cd r and cd rw and you'll be ok. The disassembling might be a bit tuff but it's worth it. I had to replace my hifi laser and after i did sound was incredible again no skipping. Make sure when opening your system you power it on and unplug it to make sure all charge is gone wait 30 minutes or so before you go and operate.
Feb 10, 2008 | RCA 100-Watt Stereo System With 5-CD...
Fw316C cd player will not read discs
Buy A CD Lens Cleaner and put it in to the CD Player and keep retrying until the drive plays it and then follow the instructions for the CD Lens Cleaner after its finished try playing a CD if it still wont play try another disc and if it does not play that try reset the player by unplugging it for five seconds if it still wont play the CD drive has failed in the drive and you need a new stereo. Stereos dont last forever so dont be surprised if you need to buy a new one
Aug 17, 2007 | Philips FW316C37 Shelf System
No Disc error, won't read any CD
rca does not sell just the laser it sells the base assy. it consistos of the laser & the spindle motor on the metal base. no circuit boards, thoes you will need to remove off of the old one. the list price from rca is $136.10 CDN. replacing the part is not too hard, but take a little time. good luck.
Feb 13, 2007 | RCA RS2501 Shelf System
RCA RS2652 Shelf System Logo
196 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
