Question about Panasonic KX-T7730 Corded Phone
How do I set the time
I have in my office a Panasonic KX-T7730 system. The technicain who fixed it is no longer working. How do I set the time? I looked in all manuals I could find both printed and online but there is absolutly nothing on how to do this.
  • 4 more comments
  • Josh Wald
    Josh Wald Oct 02, 2007
    Thanks Mr Guest. I appreciate kpuddicombe5 trying to help. However, I could find no mention in the manual how to set the time.
  • Josh Wald
    Josh Wald Oct 30, 2007
    Gaz221269, I dont know what phone or system you are referring to but it certainly doesn't work with my phone.  When you press SP-PHONE and then 77 you are supposed to get some extension certainly not enter the programming mode.
  • gae04 Jan 05, 2008
    Can't set the time and date in my KX-T7730 Phone. Please help. thanks!
  • Anonymous Jan 07, 2008
    HOW TO SET THE TIME ON KX-T7730
  • Anonymous Apr 02, 2008
    Can set a date & time. I press problem then 0, in disply write PITS-PGM NO
  • bikvi Mar 31, 2009
    I can not find how to set up time. Manual doesn't say either. Thank you for your help
It's not the make of telephone you need it's the make of system. eg. I have a KX T7730 telephone attached to a KXTES824 system (look on front of big box on wall). The procedure for changing KSTES824 is (must do from the person's phone who has the main extension)
program 0 071102 5 0858 0 store program
(date) ? time am
note: date is back to front don't know what the 5 represents and the 0 at the end indicates am, replace this with a 1 for pm. Obviously if you don't have the same system this is irrelevant - sorry
Posted on Nov 02, 2007
  • barbara18 Nov 02, 2007
    I posted reply earlier, have now found out what the 5 is for.
    Press program
    then type 0
    will display current date and time
    overtype as follows
    eg. for Friday 2nd November 2007 at 8:58am you would type
    071102 (date backwards)
    5 (Friday being the 5th day of the week)
    0858 (time)
    0 (0=am, 1=pm)
    Then press store and program to exit out of the programme mode.
PRESS SP-PHONE, DIAL 77 FOLLOWED BY THE TIME IN 12 HOUR CLOCK FORMAT, PRESS 1 FOR PM OR 0 FOR AM THEN PRESS THE HASH KEY, YOU WILL HERE A CONFIRMATION TONE AND THE PHONE WILL NOW DISPLAY THE CORRECT TIME
Posted on Oct 30, 2007
Barbara 18's solution worked great for me, just make sure you do it from the "main" phone that controls all the others!
Posted on Nov 05, 2007
  • 91 Answers
Hey; i found the manual for you http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF to set the time you click the navigator button showing in the diagram .
Posted on Sep 27, 2007
  • kimberly puddicombe Oct 04, 2007
    awww- you know what u have to do press the program button you should be able to set the time there
    that is the only place where i can see where you would be able to set the time
SOURCE:
How can I get a manual for Panasonic KX-T7730 ADVANCED Hybrid System?
http://www.wedophones.com/Manuals/Panasonic/KX-T%2077xx%20Manuals/KX-T%207720%20User%20Guide%201921wa.pdf
this manual covers the phone itself but you should look for the manual for your phone SYSTEM (box on the wall that runs all yours phones)
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
I need user manual
I need the User Manual for Panasonic Model KX-TSC11MXB Made in Malaysia in english - Kindly assist.
Oct 01, 2009 | Panasonic KX-T7730 Corded Phone
We have a Panasonic KX-T7730 system. We need to block all outgoing chargeable calls (numbers starting with zero) on some of the phones (kept in the office reception for customers)
I think you're going to need a couple of things to do that. The model number of the system, and a complete set of manuals.
When you get the manuals, look up TRS. It involves setting restrictions and changing the Class of Service (COS) of the phones you want to restrict.
Carl
Jul 01, 2009 | Panasonic KX-T7730 Corded Phone
Switchboard KX-T7730
The electronic station lock requires a couple of things, first it's dependent on the system, second, it requires some toll restriction programming, and then you can put in a lock code. At a minimum, in a TA-824 series, dial 77 xxxx xxxx #, where xxxx is a 4 digit number repeated twice. That locks the set, but it might not do anything different. It's released by 77 xxxx #. If you need help, consult your programming and features manual, or post back with the model of your phone system. Carl
Jun 10, 2009 | Panasonic KX-T7730 Corded Phone
My KX-T7730 can't display, no tone.
KX-T7730 Phone must be connected with a 4wire line cord. you may be tested it with a 2 wire line connector.because other normal phones only needed 2wire line cords.Just connect a new 4w cord to under socket located to main unit & other end connect directly to the tel;system & see is the phone confirmed OK.
& let me know .Good luck.
[email protected]
May 25, 2009 | Panasonic KX-T7730 Corded Phone
Is there a Panasonic cordless kx-t7730
The chances are, if you have CID you don't have to worry....the first call after 3am will fix it. If not, programming from extension 101 and 000 will fix it.
Any industry standard cordless phone will work on a Panasonic system...are you plugging it into a system phone port with the sytem phone? If you are trying to make both work on the same port, you have to tell the system that. Program option 610 in a TA series or 600 in a TDA series will set a Paralleled phone so both can work.
If you don't know how to get into System programming, your installer or dealer should.
Carl
Nov 02, 2008 | Panasonic KX-T7730 Corded Phone
KX-T7730, all the phones connect with operator ring at the same time when having an incoming phone
please i need your help,i use KX-T7730 in my office and of recent when incoming calls comes in all the phones in the office starts ringing and also i would like to know how i can lock and unlock the phone so as to prevent other users from accessing it.Thanks
Apr 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
5,885 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
