Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
I can't get the blade tight enough
The blade rotates, but is not tight enough. As soon as you touch the blade to the wood, it stops. Can anyone help?
  • 1 more comment
  • djo1220 Apr 26, 2009
    on my craftsman I cant find a blade lock to allow tightening!!
  • David Ford
    David Ford May 11, 2010
    Is it possible that you have one of the flanges on incorrectly or that a spacer is missing from under the inner flange ( if it has one). If neither give me the model and brand and I will find a schematic and see what I can do.
  • Marc Buck
    Marc Buck May 11, 2010
    Are you using the supplied tool to tighten the blade?
    Sergeant:
  • 187 Answers
If you tightened it enough and it still slips than it may be missing a spacer Try adding a washer to the arbor of the same size on the nut side of the blade.
Posted on May 08, 2009
I have installed a new blade in my circular saw R32021 and the blade stalls even before I begin to cut wood
by stalling do you mean that the blade stops spinning or the motor stops turning
if the blade stops spinning then the mounting bolt for the blade is not tight enough
if the motor stops spinning , junk it and get a new unit
Jan 20, 2017 | Blade Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
My jointer not make the wood flat
You might have the outfeed table lower than the blade. If the outfeed table is adjustable, then you can check it easily with a steel ruler. With the Power OFF, lay the steel rule on edge on the outfeed table so that it hangs over the blade. Rotate the blade by hand in the forward direction. The blade just just barely touch the ruler. If the ruler is bumped up and pulled forward by the blade, then this is the problem. If your outfeed table is not adjustable, then you need to adjust your blades. If this is not the problem it may be that your wood is not uniformly dried.
Jul 25, 2012 | Delta Masonry Tools
Blade is slipping, whole spindle is slipping, could barely get blade off slips when i try to saw
From the description it sounds to me like the bolt holding the blade in place isn't tight enough, obviously. If there isn't a button on the saw that stops the blade from rotating when you're changing out the blade. Try this--when tightening down the blade, put it on the saw, then open the guard and rest the blade on a piece of scrap wood to stop if from moving. Then fully tighten down the bolt that holds the blade in place and you should be fine.
Jul 30, 2011 | Porter Cable 12821 7 1/4" 40 Tooth 5/8"...
When using saw the blade comes to a stop on its own thro wood
Does the motor continue to run? If so, the blade retaining bolt may not be tight enough. Most saws have a 'stop' pin which locks the drive during the blade tightening procedure. Make sure the blade is very sharp to reduce cutting effort. Hope this helps!
Feb 07, 2010 | Saws
One fan blade stopped working and is hot to touch
The motor is 'locked up' that's where the heat is coming from. It may have a bad bushing or something is jammed. Give it a good look over you may see it. Does the blade feel hard to turn?
Sep 08, 2009 | Minka Aire F602-BNCH Gyro? Fan
The 15/16 nut that holds the blade on is locked tight.
Had the same problem with my mower. Find a length of metal pipe that will fit over the handle of your socket wrench and it will give you more torque. The nut on mine would not even budge with a 12" extension bar, but when I put a 3ft steel pipe over the bar, it popped loose with very little effort. I also used a wood block to hold the blade tight
Jun 22, 2009 | Mtd Products Yard Machines 158CC Tiller
Have a 12 inch tradesman miter saw and can not change the blade
the nut maybe a left handed thread. the norm is righty tight. lefty loosy, try the oposite.
Apr 09, 2009 | Saws
Need to change saw blade, lost instructions
1st, !!UNPLUG the saw!! Wear gloves to prevent nicks from contact with the saw blades.
If this is a handheld 'skill-saw' type saw, use a piece of wood to chock the saw blade from turning as you use a proper size socket/wrench to loosen the bolt which holds the blade.
The bolt will loosen counter-clock wise. It will probably be very tight, and you will have to use some effort to loosen it.
Remove the bolt, lift the follow guard and remove the blade.
Replace the blade with a like size diameter blade by raising the follow guard, inserting the blade, replacing the bolt, using a piece of wood to keep the blade from rotating and TIGHTEN the bolt. You will almost feel as if you need three hands to accomplish this procedure but its been done millions of successful times.
Good luck. :)
Mar 11, 2009 | Hand Tools
How tight should the blade bolt be on a cut off saw
You've answered this yourself. The blade only needs to be nipped up enough to grip. If it slips, it will tighten. Thats why, some machines have a left hand thread, as they always rotate so as to tighten in the event of slippage.
If the blade slips under normal service, suggest you clean both blade and the flanges, and just do it up a little tighter next time.
Mar 04, 2009 | Ace Hardware Ace Chop Saw Cut - Off Blade
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
213 people viewed this question
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
