Question about Garden
Engine slow turning over, won't start
I have an ariens 1540 ezr that has an electrical problem, i think. The mower has been sitting for a few years so the battery was dead. I replaced the battery and noticed corrosion on the + terminal. The mower would only turn over slowly, even when being jump started from my car. I bypassed the corroded wire and connected the cable at the opposite end at its origin but it didn't help. any suggestions?
I have a Ariens EZR 2048 Ridding Mower and want turn over even If i shorten it out by the siloniod
try jump it at starter if jumps start bad silinoide if no power to silnoid bad switch
Sep 08, 2014 | Ariens Garden
Ariens ezr 1540
Check your drive belt above blade belt
Dec 21, 2013 | Garden
Ariens ezr 1540
The only function of the solenoid is the engaging of plunger (the click). You could have a bad starter, a bad battery or something preventing the engine from turning over. Thy removing the spark plug and see if the enging will thrn over
rk p, ug and see if the
Aug 15, 2013 | Garden
When turning on pto blows the fuse
Look over the entire wiring harness wherever it may be touching metal as it probably is chaffed, simply tape and zip tie it away from the ground source.
Aug 03, 2011 | Ariens Zoom 42 In 165 HP Briggs Stratton...
My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Sep 26, 2009 | Ariens 34 In. Zoom Series Riding Mower
Looking for manual Arien EZR 1742
Go here:
http://www.ariens.com/corporate/pages/partsradar.aspx
Hope this helps
Jun 10, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
334 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
