Question about Intertherm P3RA-060K Air Conditioner
Suddenly stopped cooling
Unit is about 2 years old. always worked great. a couple of days ago it just stopped cooling. i tried leaving it turned off for a couple of hours in case something froze up, and of course i checked the breakers and went outside to see that it was running. it is blowing, just not cold. the inside temp was 84, i let it run a couple of hours and it didn't drop 1 degree. I can't hear the compressor running, but i never listened for it before, so i don't know if i should be able to hear it or not. I have noticed that when it's turned on, the lights in the house will dim for a second every couple of minutes. since it is only about 2 years old, might it still be under warranty?
  • 306 Answers
Sounds to me like the run capacitor is bad. It is a dual one which means runs the fan and the compressor. No big deal capacitors are only 10 bucks and easy to replace.
First turn off the electricity to unit at breaker would be best. Next after you open the access panel locate the capacitor and make a note which wires go where one side is marked fan the other is herm. in the middle is comm. Take the old one in and get a new one same size and reinstall. Now parts only have one year warranty but they should have a discount on a person that bought a unit from them if you talk to them and tell them how can this happen only 2 years old. you know the story they might just throw one in for free to keep good business practice. Let me know how it goes. ken
Posted on Apr 16, 2009
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
May 11, 2011 | Porter Cable Garden
Our 2-year old Whirlpool side by side refrigerator is not cooling. Cooling power seems to have been reduced over a couple of days as it didn't die suddenly. Initially the compressor wasn't going. A...
ONLY THING I CAN TELL YOU NOW IS THERE IS A LEAK SOME WHERE IN THE SYSTEM. AND I M SURE THE NEVR DID ANY LEAK CHECK ON THE SYSTEM IF YOU DO NOT WANT TONGET AN OTHER REFRIGERATOR; TRY GET A REPAIREMAN WITH EXPERIENCE AND HAVE GOOD TESTER EQUIPMENTS
Oct 24, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Refrigerator stopped cooling 2 days ago. Freezer works fine. What is broken? Appliance is four years old. Replaced compressor almost exactly 1 year ago.
Check the fan in the freezer and be sure it's working, isn't blocked by product or isn't clogged with ice. If this fan isn't working the refrigerator section won't cool properly.
Jul 18, 2010 | Maytag Refrigerators
Kenmore refrigerator stopped cooling 6 days ago and started working again 2 days later but not very cold.Stopped cooling again 2 days ago.Now it is frosted up in the back of the freezer,What could cause...
There are several things that could be causing this. Your compressor could be going bad. Your freon is low. Think of your refrigerator as a air conditioner. Pull it out and vacuum all the dust from your filters, make sure the water is draining properly and not clogged up. Is your unit still under warranty. How old is your unit. Try this. Unplug the unit for about 5-10 minutes, this will give it enough time for the compressor to cool down. Plug it back in and listen for the compressor to kick on. That's the big black round thing at the bottom in the back of your refrigerator. Listen to it and what the sound is, does it click when it turns on, does it shudder when it turns on. Let me know the sound. By unplugging the unit and doing this the compressor should kick on in 1-3 minutes after plugging it back in. If your unit is over 8 years old you might consider another one. Check out craigslist, as you can get some great deals. Let me know if I can help you further.
JimmyC
Sep 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Refrigerator will not cool
compressor is failing - don't blame it after 13 years!
Sep 06, 2008 | Whirlpool Refrigerators
Hamilton Beach 87330 water dispenser: no auto shut off
Glen,
We purchaced this water dispencer about 2 years ago, everything was working normal, water heater works fine and the cooler would come on and go off normally,until you dispenced cold water and then the coller would cool down and shut of like it's supposed to.
Afetr a couple of years , one day it started cooling continuously and wouldn't stop, I've just shut the cooler switch off on the back of the unit until i can figure the problem out,unit #(87330).
I believe the problem is in the circuit control board, but with out further testing i can't be sure .
Sep 01, 2008 | Refrigerators
Ipod problems
try your hardest
Aug 05, 2008 | Apple iPod nano
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Intertherm P3RA-060K Air Conditioner Logo
321 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
