Question about Roper RAS8445KQ Top Load Washer
Have roper model #ax6245vlo filled up with water then does not spin
  • nellwill Apr 16, 2009
    now what do i do
  • 686 Answers
GO TO www.repairclinic.com ENTER MODEL NUMBER AND LOOK FOR PART 1195967. THIS IS EASY TO CHECK BUT REQUIRES REMOVING PUMP AND MOTOR TO INSECPT. TO REMOVE PUMP AND MOTOR LAY ON IT'S BACK AND REMOVE 2 RETAINER PUMP CLIPS SLIDE PUMP OUT OF WAY AND REMOVE 2 MOTOR RETAINING CLIPS THE IF ANY OF THE FINGERS ON THIS PART ARE BAD CHANGE IT OUT IF NOT YOU MAY HAVE A BAD LID SWITCH
Posted on Apr 17, 2009
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Roper model RAL5144Bw1
Look and see if the belt has broken off and the motor.
Jul 01, 2013 | Roper Washing Machines
Diagram of motor to transmition
You can try Servall.com or do a general Browser search on Roper Website. The Servall people are really good, some may be in your phonebook.
Jan 16, 2012 | Roper Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
The washer's springs configuration
They are hooked from the bottom frame to the carriage that holds the tub. Not sure of the model you have but most Whirlpool (They make kenmore, roper, magic chef and others) There is a ring around the top of the outer tub that is filled with water from the factory. Make sure it still has water inside. It acts as a damper helping to balanced the tub also.
Oct 13, 2009 | Roper Washing Machines
Have a roper ras7133kq1 top loader. It will fill with water and will do nothing else. when i manually set it to spin it makes a squealing nose and the water just drains out.
go to www.repairclinic.com and enter your model number. the first part you see is what is wrong with your washer's spin. replace that and you'll be good. this is found underneath between the motor and the transmission.
Apr 03, 2009 | Roper RAS8445KQ Top Load Washer
Roper model #RAS7133pqo
I'm having the same problem. The noise we hear is the water pump, does your washer have a belt?
Please forward to me any tips you may get, I'll do same
Lew
Feb 03, 2009 | Roper RAS8445KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
Sep 16, 2008 | Roper RAX4232KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
143 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
