Question about Garden
Need tool to adjust ryobi powerhead - Garden
3 Suggested Answers
  • 1129 Answers
SOURCE: ryobi line trimmer ry26921 will not continue
Some times the carb diaphram gets weak and needs replacement while you are doing this spray it out with carb cleaner and blow out with compressed air, reassemble.
Posted on Jul 14, 2009
dontbother10
  • 2220 Answers
SOURCE: Where can I get the tool needed to adjust the carb
eBay search for Walbro tool.
Posted on Jan 25, 2010
I have a 31 cc Ryobi weedeater. When I put it on full choke it starts. Then when I put it on half choke, It starts, revs good for a few seconds then dies. What do I need to do?
This is fuel starvation, check/replace the fuel filter in the tank, no better then you need to make an adjustment to the carb, unfortunately you may need a special tool as many carbs today have anti tamper adjustment screws ( they have no screw driver slot in the head ) check the head of the screw and order the relevant tool off e bay, once you have the tool make small adjustments at a time, they are fuel screws not air screws so unwinding them will richen the mixture, make the adjustment to the L screw. this will be the screw nearest to the cylinder and will help with acceleration, the H screw will control the maximum rpm.
Apr 17, 2018 | Ryobi Garden
Ryobi problems
Yes sir it is. You need to adjust the carburetor. Unless you have an adjustment tool you'll have to take it somewhere to have this done.
Jul 16, 2014 | Ryobi Garden
Powerhead runs but tools (blower, trimmer. edger) won't work.
Hi Jim Kamph...
You have a broken drive cable inside of the trimmer.You will need to replace the drive cable
Please rate me
Bud
Sep 26, 2012 | Ryobi Garden
I have a RYOBI pole saw that starts fine, but there is a disconnect between engine and saw blade. The blade will not turn.
I assume you have the Ryobi powerhead with the multiple tool shaft (can use it with an edger, blower, trimmer, and pole saw) If so, does the powerhead square drive spin when you squeeze the throttle trigger? Does the chain move freely on the saw end when not connected? Is the attachment fully inserted into the powerhead shaft (small spring-loaded button should pop out of the hole when fully inserted.
Aug 26, 2011 | Garden
NEED THE PART NUMBER FOR THE SPECIAL TOOL THAT CAN TURN THE CARBURATOR MIXTURE ADJUSTMENT SCREWS FOR A RYOBI MODEL NUMBER RY28040
if you get a small flat edged screwdriver or a tuning screwsriver for lelectronics they will both work the same. you shouldn't need a special tool for that.
Jul 01, 2011 | Ryobi Garden
Need part for ryobi tp-30 pole saw
ill sell you a tp30 that has under 100 hrs on it. only needs carb adjusted dont have tool $125
Mar 23, 2009 | Ryobi Garden
I need a tool to adjust the mixture screws on my ryobi chainsaw
Most mixture adjustment screws are flat slotted types and usually you can use a flat headed screwdriver to adjust them.
Feb 27, 2009 | Ryobi Garden
Ryobi pole saw model ry52502
my Ryobi RY52502 starts but when i change the lever from start to run, it will shut off
Feb 03, 2009 | Remington 111409 - 01 6" Branch Wizard...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
