Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Replacing HDD's on WD MyBook World II won't format
I have a WD My Book World Edition II dual drive unit (2x500Gb WD's). I want to use it with newer 1.5Tb HDD's (Seagate's)but it won't recognize them. Once formatted via either Windows XP or DOS, still don't recognize them and sometime the unit will not even power up. I viewed the contents of the original drives and there were multiple partitions on them which I can't recreate. I have even formatted the original 500Gb HDD's and now they aren't recognized. How can I format the new or old drives for the unit to recognize them for what they are? Is there perhaps a firmware limitation with the unit to only allow 2x500Gb or combined 1Tb? I can't find any information to this extent anywhere on the net, thus far. Thanks!
  • wahlstfj Apr 17, 2009
    Sarcasm is the last refuge of a defeated wit. We're all here looking for answers, not criticisms. I certainly don't consider this a loss in any way as I still have two perfectly good 1.5Tb drives that I can alway place into another enclosure. Thanks for the comments though, I'm sure everyone else will be most enlightened by any of your future posts.
I was attempting something similiar -- replacing my World Edition II 500GB drives with 1TB drives. My research unearthed two things... These units will only work with Western Digital Caviar Green drives. The blue ring won't light if other drives are installed. I also read (in a couple spots) that the unit's O/S is stored on the hard drive (as opposed to be stored in Flash memory). If this is true, you would need to image the old drive to the new (using a tool like Ghost or True Image), and increase the partition size as part of the imaging process. I don't know if this would work, as I opted to not proceed with the upgrade. For me, the new version of the World Edition II (WDH2NC20000 and WDH2NC40000) turned out to be a better option than upgrading. These units provdide the extra space and are MUCH faster than the old ones.
Posted on Aug 26, 2009
Testimonial: "I appreciate the input, since I've scrubbed the orig drives, I guess everything's going back to WD for fixin. Looks like I'll be buying a new unit too"
    Problem Solver:
  • 7 Answers
You can upgrade, and you can use NON-WD drives.
However, you will need to do a bunch of stuff, which is not overly hard, to make this happen. When using non-WD drives, you need to disable the thermal monitoring of this device. You will need to enable SHELL access via SSH to the device. You can Google most of this, there are a few sites with step by step walk throughs.
Here is the link for the hard drive upgrade and non-WD replacement instructions:
http://mybookworld.wikidot.com/add-new-hdd-to-wdwe
Posted on Dec 09, 2012
As far as I now,
mybook worlds require EXT3 partitions.
Are you able to connect to the mybook, when the hard drives are not connected?
If so, then it shouldn't be a problem to format them with gParted (linux livecd), to ext3 of course.
Hope this helps :)
Posted on Jul 13, 2009
How do I format my WD MyBook Elite to FAT32
Using FAT32 these days on a current OS will half the
HDD storing capabilities especially if your unit uses'
a SATA HDD , FAT32 speed compared to NTFS is
less than half and the compression tool on NTFS
are more compact and compile better , also FAT32
is used to apply an operating system not for external
storage and if you are using your external storage HDD for holding an operating system to the HDD
will be suspectable to contracting viruses and
putting your data at risk , since the external HDD
is static and does not run through the OS registry
Jan 28, 2010 | Western Digital My Book Essential Edition...
When I connect to My Book it doesnt not read the
If you are running Vista, You might be one of many people who are reporting an update that is causing some buggy behavior. Try this:
Connect the drive but do not Format the drive, right click 'my computer' then 'manage' go to 'storage/disk management' view the drives; your usb drive will not be allocated a drive letter. You can set one manually or leave it for about 2~5 minutes for one to be allocated auto. Each time you connect the drive you may have to do this.
Oct 11, 2009 | Western Digital 500GB My Book World...
Cant connect my 1TB WD world edition to my linksys router
Your My Book World should not be formatted or you will lose all ability to access it through the Network -- it will simply become a hard-drive at that point. There is software installed on the hard-drives that communicate with your Router in order to obtain an IP and be available as a Network Drive. If the drive and the Router are communicating, you should see an IP in the DHCP list of your Router. It is possible that the My Book World is not setup for DHCP, so if it is placed in an alternate environment with incompatible static IPs, it won't be able to access the Internet or be available locally. You can try a hardware reset on the drive and see if it pops up in your Router's DHCP/Client list, at which point it should also appear locally and over MioNet (MioNet will need to register the device to an account before it will appear in MioNet, but it must detect the drive locally in order to attach).
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
Jul 02, 2009 | Western Digital 500GB My Book World...
Defrag a wd world book
The file system used by the WD My Book World unit is Linux based and does not fragment in the same ways that Windows users are used to dealing with. You will not need to worry about fragmentation.
If you are interested in a more geeky, but still somewhat simple explanation at http://geekblog.oneandoneis2.org/index.php/2006/08/17/why_doesn_t_linux_need_defragmenting
Happy computing! :D
-= M =-
Apr 01, 2009 | Western Digital My Book World Edition II 2...
Can't open My WD Mybook Home edition 500 GB External Hardrive
sounds like the hard drive is failing... i suggest you find yourself a data recovery program soon
Jan 05, 2009 | Western Digital My Book Essential Edition...
WD Hard Drive Not Detecting
Yes, this can be done via the user web interface, by typing in mybookworld or wdstorage into the web browser and the shared storage manager should come up. If you go to general setup there should be an option to update network settings.
Oct 31, 2008 | Western Digital 500GB My Book World...
WD mybook world won't work on mac?
Window and OSX - fun and joy.
Since you formatted a 1TB drive and it works fine in Windows, I have to concluded the the drive was formatted NTFS.
Here is the issue in a nutshell, OSX supports reading NTFS but have very limited write cababilities.
If you want both Windows and OSX to have full access to an external drive you should format it FAT32. The only issue then is that under normal conditions a FAT32 drive has a maximum size of 32GB.
I would partition the drive to have 1 or more FAT32 partitions and then have the rest of the drive NTFS.
Is the OSX version correct or should it be 10.3. If it is actually 1.3 it would mean you have the OSX Server edition that originally came out in 1999 and it may not have very good USB support - version 1.2 would only support 1 USB device.
Oct 16, 2008 | Western Digital 500GB My Book World...
How do you set up multiple WD Anywhere users on the network to share the same MyBook World Edition
hey,
-No WD Anywhere allows 5 users I think.
This could only be the solution, if you installed WD Anywhere on other PCs before
Check out the MioNet site, think they give options for new users.
if this is not the problem, I don't have a solution by now.
bye
Feb 08, 2008 | Western Digital 500GB My Book World...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
8,592 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
