Knob doesn't advance
Kenmore front load washing machine 417.41142000. water fill but then it doesn't advance. can hear humming door lock light is on. tested lock was good
  • 6,784 Answers
Hi, the timer is malfunctioning. you will need to replace this device. i have provided a link below to the actual REPLACMENT part you will need.
CLICK HERE TO BE DIRECTED TO THE REPLACMENT TIMER
Posted on Apr 16, 2009
  • Michael Masters
    Michael Masters Apr 16, 2009
    Please rate and god bless:)
HUMMING NOISE NO LIGHTS AND WILL NOT WORK.
possibly the door switch /lock has failed . try leaning against door and press start button.
Sep 08, 2015 | Whirlpool Duet 3.8 cu. ft. Front Load...
Machine will fill and wash , but will not fill and rinse
AS YOU SHOULD KNOW KENMORE APPLIANCES MADE BY MANY DIFFERNT COMPANIES AND WITHOUT FULL MODELL NUMBER IT IS HARD TO SAY WHAT IS PROBLEM BUT COULD BE DOOR LOCK OR MAIN CONTROLL BOARD PROBLEM
Dec 09, 2013 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Kenmore 43142 Front Load Washer
Just moved front load beaumark washer into a new house, and it won't fill with water. the display lights up and you can here washer trying to fill (humming noice). All display lights come on and it...
It sounds like your water inlet valve is either not getting a signal to let water in from your control board or the water inlet valve is defective. Since you are hearing a humming noise, I would say that the water inlet valve is defective or has been damaged in transit.
Jun 18, 2011 | Frigidaire ATF6000ES Front Load Washer
Thanks in advance, my washer fills with water but doesn`t spin. not any noise.
The safety interlock switch might be bad. That's a safety switch to prevent the machine from agitating or spinning while the door is open. Close the door slowly and listen for a click just before it is completely closed. If you don't hear it, then check the alignment of the door and its actuator. If you do hear a click but the machine doesn't start, then the switch may need replacement.
Sep 18, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmorewasher 11024432300 will fill but will not advance to wash cycle
if you hear humming noise then its the unit b/w the motor and the gear but if you dont hear anything after the water load then it is your door switch.
dont forget to rate my help
Jan 12, 2010 | Kenmore 24432 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Ge adora whdvh626fww not filling with water and locks door
Can you take a look at the pump to see check why it is able to pump-in water ? Motor is still good as you can hear it trying to pump-in water.
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
Front loading wash machine
It sound like door lock unit is broken or removed from the door. Good luck !
Jun 17, 2007 | Kenmore 44042 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
