Question about Sony Cyber-shot DSC-W50 Digital Camera
Sony Cyber-shot DSC-W55
The camera hasn't taken more than 100 photos and when you turn it on it says "Access" and tells you to turn it off. It hasn't been dropped or damaged. Any ideas?
  • lemire24 Nov 20, 2008
    When I turn my camera on it has a black screen, nothing shows up, not even a blank light. Then, the lens pops in and out several times, making peculiar noises, and finally just stays out. If i press the display button it says access when i turn it on, and if i press it again it says turn camera off and back on again. I've tried taking the battery out. I've tried plugging it into my computer. I haven't dropped the camera once. Does anyone know what's going on?
  • Anonymous Nov 21, 2008
    same thing.. i get this access screen...and no other explanation...the lenses goes in and out a few times during this process, so the motor shouldnt be bad, and i can turn the option dial and get display on the screen of those options, but no picture....
  • 53 Answers
It sounds like you may have a bad gear in your lens motor unit. f you want to repair it yourself there is a guy in South Carolina who has lots of parts for all the Sony Cameras. I bought my LCD from him for $39.00 plus shipping and it works perfect. I put it in myself and saved a ton. If you buy the part from him he sends you pictures of him taking the camera apart so that you can repeat the process when you install it. I think his email is [email protected]
Posted on Mar 13, 2008
Glad I'm not alone... just bought this camera Labor Day weekend and it's only taken 42 pictures. Today it started this "access" garbage and I feared that it was no good anymore. I'll try taking the battery out like previously mentioned and cross my fingers!
Posted on Sep 23, 2007
Nope but my daughters is doing the exact same thing. She has not sent it home to me to check but I thought about taking the battery out and leaving it without power for 24 hours to see if it clears Gary
Posted on Sep 19, 2007
SOURCE:
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Replace Sony Cyber-shot DSC-W55 shutter button
Don't throw your Sony Cyber-Shot camera away!
We found a website who has created an entire comprehensive photo instructions for the Sony Cyber-Shot DSC-H Series Shutter Button Installation.
They also have the Sony Cyber-Shot DSC-H9 Shutter Button Installation Instructions as well!
Please note that we STRONGLY recommend using a flash discharger. This is for your safety and also for your camera's safety.
Hope this helps to get your camera working and start capturing memories again!
Aug 18, 2009 | Cameras
Sony DSC-W55 Access Message - lenses going in & out automatically
Please remove the Battery from the Camera then reinsert it after two minutes. Make sure that the Battery is fully charged. if menu options are accessible on the Camera then reset it to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings:
(i) Please turn ON the Camera.
(ii) Then use the control button on the Camera to the select the Setup (setting) option.
(iii) Next, select the Setup1 option then "initialize".
Performing the above mentioned steps will reset the Camera to the original factory settings. If the issue persists then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
When I turn my Sony DSC-W55 on it will say Access on the lens. The lens will come out and retract a couple times. It will beep and then say Turn the power off and on again. I have tried replacing the...
I had the same problem with the lens, just pull the lens gently until u hear a small click sound, it will be like new again. just tried it and it really works
Apr 10, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cyber-shot dsc-h3 flash problem
http://www.avforums.com/forums/digital-cameras-photography-photo-editing/826916-sony-dsc-h3-flash-wont-open.html
Sep 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W55 Date Stamp
if date and time is set in camera correct the info is attached to each photo-even though you don't see it if you right click properties of photo it is there-some models don't offer date and time stamp because if you tell the printer to do it it should add it on print
Aug 12, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber Shot DSC-W55
Why dont you clean Lens front? It might be dirty.
Jun 25, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Multiple pictures
Dear ACO107,
Please turn on Cyber-shot in camera mode and press Menu, select Mode, select Normal, OR got to Camera Mode Selection Button (top of camera near power button) and select Auto (Green Color) symbol. Problem would be solved.
May 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
172 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
