Question about Kenmore 22422 Top Load Washer
Tub support broke
My machine was in the spin cycle with an uneven load and started "dancing" around the basement. As I was going to redistribute the clothes, it starting making a loud banging noise and I noticed the whole front of the tub was loose and hanging down in the front. I assume the brackets holding it up finally gave way. Is this repairable? (Kenmore 70 Series, about 15 years? old.)
  • 686 Answers
POST THE MODEL NUMBER PLEASE
Posted on Apr 17, 2009
  • James Chandler Apr 18, 2009
    pry your top panel up at the edges with a wide flat screw driver and look inside the front panel and remove screws that hold the front to the cabinet lift up and out. Now is it the tub or the front panel that came off. repost answer and will go from there.
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
What's the purpose of the tub displacement sensor
To detect excessive wash tub movement and shut down the wash cycle. Here is a copy of my post from a real DIY forum;
Google this Neptune TL Washer FAV6800AWW 5 post down.
Here ya go.....in this post I discuss the issue related to unbalance error codes DC and UC;
Your FAV6800A or FAV9800A is going off balance with DC or UC unbalance error codes during spin cycle and you see/hear the wash tub banging around at the start of Spin Cycle of the wash cycle or a Spin Only cycle. If this is the condition the TDS (Tub Displacement Sensor) is working as designed and signaling the Control Board properly of an unbalance wash load condition.
The Control Board receives a varying D.C . Voltage from the TDS sensor and if the out of range D.C. Voltage limit continues the Control Board will halt the Spin Cycle and try to redistribute the wash load. If you are interested I will show you how to monitor the TDS input to the Control Board with a DVM.
The Control Board then starts the Spin Cycle again. If the wash tub/basket out of balance condition continues the Control Board will attempt another redistribute of the wash load. After several attempts (4 to 5 I believe) the Control Board will shut down the Spin Cycle and send a error code DC or UC to the LED display of the FAV6800A, my machine type. And I believe a text statement to the LCD screen of the FAV9800A machine i.e. something like "Unbalance Condition" I'm not sure what the text message is.
If you need help open a post in that repair forum and I will try help you through your issue.
The forum is free and my time is free I just don
Feb 15, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fisher and Paykel Washing Machine "Pride 5.5" Smartdrive 8 Model MW058U. Washing tub thrashes around violently when wash cycle starts any spinning - even during rinse cycle. Load looks even around...
Hi just found your posting.Do you still require help?The problem with your machine sounds like your suspension rods are faulty.Please reply and I can help you rectify this fault.Looking forward to your reply.
Jul 14, 2010 | Fisher and Paykel Washing Machines
Washer does not finish cycle..it stops at spin and it displays a 'dc' code...what is this
The Service Manual for reference. Sears Parts Direct for reference.
dC code from the Service Manual = Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
Your wash tub is banging around during the spin cycle correct?
You can redistribute the wash basket load until the cows come home the issue will only continue to get worse. Maybe start throwing uC error codes to the console display for continuous unbalance error code.
Your FAV6800A or FAV9800A has a Clutch malfunction. It can be corrected if you are handy see this DIY fix Clutch Fix. post.
If you decide to dive in I will help you through the fix………Rich
Feb 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Washer tub bangs when in spin cycle
There is not a repair guide , sounds like a spring may have broke or came loose inside on the frame take the front panel off to check for loose parts.
it may just be an off balanced load as well.
Phil
Apr 15, 2009 | Admiral AAV7000A
Maytag atlantis wont spin cycle
this could be one of three things, 1. Rinse hold (an option to save the washing sitting crumpled when you are out) release the rinse hold button and it will spin.
2. You have a blocked drain or uneven load (if a washing machine spins with a full load of water in it it would dance around your kitchen and eventually break apart the weight is too much, it has to remove the water to a level within a set time or it will stop, or if its a uneven load it will attempet 3-4 times start a spin.
3. your motor brushes are worn (brushes last around 2-3 years depending on use) or board failure, first signs of this can be it will not spin, then it will not rotate at all try to spin it with no load (no washing) then add a couple of wet towels. if no spin it could be either of the two best way to check the brushes is to remove them and check the length they start around an inch long.
Always isolate the electrical supply when removing things from the machine.
Nov 12, 2008 | Maytag Washing Machines
Kenmore 22422 Top Load Washer Logo
184 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
