Sharp aquos 28 inch flat plasma television. monitor won't come on. power source good. is there a fuse i can replace?
    Brigadier General:
  • 3,917 Answers
This could be 1 of three things! 1-main lcd panel
2-y sustain module
3-z sustain module
This is something you cannot do yourself my friend.
open the set and look for any blown fuses or a shorted transistor, now if do not have repair skills call the repairman this could be a headache
he should not charge you too much since this is an old tv. with parts and labor no more than $150.00
good luck
Thanks
Posted on Apr 16, 2009
A BOLT OF LIGHTING HIT MY HOUSE AND TV WILL NOT POWER UP. COULD IT BE A FUSE?
It will be the fuse on the power bread board, only replace with same size fuse. As using a bigger or smaller fuse can cause more issues.
Jul 22, 2015 | Sharp Aquos Lc-26dv28ut 26" Inch Lcd 720p...
After power surge aquos tv won't turn on
hi ther is a overload fuse on the psu board which will blow after a surge of power but to get to it you will have to take the back off
Nov 09, 2011 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I have a sharp lcd 32 inch it stopped working, it won't turn on.
Try to check the main line and if its ok proceed to the power chord then to transformer or the fuse and you look it they are fine look for a technician to check your tv.Choose a better technician near from your place.
Nov 06, 2011 | Sharp Aquos LC-C3234U 32 in. LCD TV
My 32 inch Sharp Aquos acts like it isn't plugged in..The power light doesn't even come on...
Can you take the back off the set and check the fuse? Located to where the AC plug wire goes into the set. Can be checked with a ohmmeter for continuity. If bad do not exceed the amps of the original fuse when replacing because there may be a short in the circuit that will blow the new fuse and a higher amp may damage the set to a worse condition. Inspect the power supply for charred components across the AC line and replace.
Nov 03, 2011 | Televison & Video
I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
The main power transistor in the power supply appears to have failed. It has also blown the fuse. Not a job for the DIY'er unless you have serious electronics experience.
Mar 08, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Scratched sharp 46 inch lcd screen can it be replaced
The lcd screen is the most expensive component of the lcd screen/tv/monitor.
It makes no sense to try and replace it as first of all you won`t be able to find the part number required to do that job (e.g. the screens are internally made by sharp // special orders are placed to companies that only start the process for orders greater than tens of thousands of items) and secondly after a lcd panel has been replaced / installed you need to configure the colors, luminosity, contrast, balance etc through a data cable.
I am really sorry for your sharp lcd screen.
Nov 30, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp tv displays 'please wait' but no picture. and my source input display menu will not come up. model sharp acquos 32 inch.
You will have to replace DIGITAL PCB ASSEMBLY to correct the problem, I assume, that your TV is lc32d40u?
Sep 26, 2009 | Sharp AQUOS LC-45D40U 45 in. LCD...
No power to tv after unplugging and replugging
either the fuse is burnt out inside or the the problem is the power supply board. You can remove the back cover to see if the fuse is good or not.
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37GD6U 37 in. HDTV LCD.
I've had this problem with my Aquos. I had Sharp send out a tech. and they upgraded the firmware on the motherbd. to version 1.04 (main and monitor) and this took care of the problem
Sep 16, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp LC-PD50U No power
I have just had this same problem. Did it tuurn out to be a power supply or the fuse?
THank you,
ALan
Jan 05, 2008 | Sharp Aquos LC-PD50U 50 in. Plasma...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
