Question about Amana 25.8 cu. ft. Side-by-Side Freestanding Refrigerator SRD26VP
My ice maker can't make ice.
My ice maker is trying to make ice (I hear the clicking), but no ice is being made. I have the wire in the ice maker down. Is that correct?
ndgregory@aol.com
    Problem Solver:
  • 14 Answers
Sounds like the water may be off to your unit or the solenoid is not opening to feed the water to the ice maker.
Posted on May 16, 2009
JennAir JSD2789GES ice maker /water dispenser
if the water is stored in a container matrix in the fridge (to cool it down b4 dispensing) it may have frozen up. best give the unit a complete defrost to see if this is occuring, if so the thermistors may be faulty.
Jul 07, 2007 | Maytag MZD2665HE Side by Side Refrigerator
Ice maker doesn't work
Testing the ice maker:
As far as the smaller line (1/4") you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. For whirlpool and its subsidaries,you can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked m and the other in the cicle marked n. Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. For GE, you turtn the ice maker off, wait about a minute then turn back on, water should automatically shoot water in the icemaker. That will tell you the water valve is good and icemaker is bad, or the ice maker is good and the valve is bad if no water. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Also check the fill tube to be sure the no ice is blocking water from coming in.
Jun 17, 2012 | Kenmore Refrigerators
Frigidaire Superba Ice maker - no water flow
Jun 06, 2012 | KitchenAid Superba KSBS23IN Side by Side...
Hi, I have a amana af12538aes french door refrig. Starting this am, the control on the door does not deliver ice only cold water from the ice button. The ice maker is making ice. Is this a control...
Is the display flashing when you try and use it or can you hear the dispenser door opening and closing rapidly (clicking or clapping sound)? These are prone to the board going bad and losing the dispenser. Is the "ice" light lit on the dispenser? The touch pad could be bad too. Do you hear the auger motor turning the ice when you press the dispenser? or just the "shhhhhhh" of the water coming out?
If there is ice in the bucket then that is not the problem. Dump it and listen if you hear new ice drop to verify.
There is no such part called an "ice element". Ice maker-yes.. Heating element-yes.. Ice dispenser-yes
Mar 04, 2018 | Amana AFD2535DES French Door Refrigerator
Kenmore Model 106.54619300
not knowing your ice maker model
if you have a white box like cove on the end,
pop that off
you will be looking at the ejection moter wheel
to the botom right, you should see two holes
one T one H jumps those out with a small peice of wire, you may need to hold the door switch on the freezer,,,,
if you jumped it out correctly, yo will hear a definitive click,
take out the jumper
watch the whole cycle 3=mins
keeping an eye on the ice machine the whole time
if it does everything but eject your motor is stipped
and you will need a new one
Oct 06, 2009 | Kenmore Refrigerators
Kenmore Elite, Ice maker will not produce.
Try taking the ice despenser out and carefully melt any ice in the freezing tray. Sometimes the ice doesn't fully eject, leaving behind residue that will eventually become too full to produce ice. You can melt it by slow running hot water or hair dryer low speed.
Aug 07, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
No ice
your unit may be having an issue with the Ice maker itself. The ice shut off lever on the side of the ice maker may be broken. If so the ice maker would have to be replaced. You can try to move the lever up and down( metal wire type lever) not much about half an inch or so.If you hear a real soft click its ok if not, time to replace it.
Jul 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Sub-Zero 642 ice maker
When the drawer is opened, trhe "full arm" swings up and out of the way. When the drawer is pushed back closed, the arm should swing back down. If it is unobstructed, the icemaker should make ice.
One thing to try is with the ice tray removed, push the plate (that holds the ice tray) back into the freezer. Lift the full arm up and down. It should easily move and you should be able to hear a slight "click" when moving up/down. If not, you might have a bad switch in the ice maker unit...replacement time.
Mar 25, 2009 | Sub-Zero 642
Refrigerators Logo
102 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
