My 3 1/2 yr old son was pushing buttons on the front of the tv this morning and it started flashing the features real big across the screen over the channel that it was on at the time and now it will do nothing but this, like it is stuck. It will not even power off, I had to unplug it to shut off. It is like it is locked up in this mode. Help!!! Can I fix this.
3 Blinks means Convergence -replace Both STK ICs they are big black ICs and will have Part number on them STK392-110 Mats Electronics sales ICs 1-800-628-1118
Just like a few of your other readers mentioned, we pushed the button below the AV/TV button for 3 seconds and the screen unlocked. Thanks for everyone's advise, we were ready to throw out the TV.
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
If it's an Innovage brand Jumbo remote, try this... There are 2 different versions of the Innovage Jumbo remote, an old and a new. For the old version: 1. You have to have the TV or DVD turned OFF. 2. Then, you have to push CODE SEARCH button once for 3 seconds till it lights solid 3.
Then press TV (or DVD) button once till it lights once and turns solid
and press the ON/OFF button very slowly and repeatedly as many as 300+
times to wait for the TV (or DVD) to go on. 4. Once it goes on...STOP and IMMEDIATELY press ENTER before you pass up the code or you'll have to start over!
This
is very frustrating but my advice is to take it slow and methodical.
Think the tortoise and the hare...if you go too fast, you'll redo it
several times because you'll keep passing it up and accidentally turn
the TV on and off suddenly and miss the code. -------------------------------------------- For the newer version: 1. Turn the TV (or DVD) ON. 2. Press CODE SEARCH once and it blinks. 3. Press TV (or DVD) once and it blinks. 4. Press ON/OFF button only ONCE. 5. Wait as it automatically searches for the code by itself. It will have a slow long blink between each code it searches. 6.
Stay alert because when the TV (or DVD) goes off, you IMMEDIATELY have
to push ENTER to lock in that code before it goes onto the next one.
(which it will even if the TV is off)
Is the light blinking a certain number of blinks then pausing?All mistubishi have a diagnosis feature built in. Try pushing the input and menu buttons on the set and holding them both in for 5 seconds to see if it will blink a diagnosis code.
my celing was leaking like it was raining out side, but my son ran some bath water and for got he turn the water on and left it ran all over the floor, and i'm down stairs watching the water come down full speed on my big scren tv,i tried drying the tv with a floor heater from front to back wake up the next morning tv still dosen't come on.. what can be the problems,............... please you can reach me at [email protected]. i really ned to no i love my tv
depending on the remote you have from rogers but the newest remote has 5 device's across the top we call it a 5 button there is a 3 and a 4 and a fat 5 button that is the old pvr remote all are pretty much the same in setting up easiest way is on 5 button remotes select the device ie. tv pres and hold setup untill light flashes 3 times enter 9-9-1 the with the tv on press ch+ button untill tv turns off once tv is off press setup to lock in the code test it by pressing tv then pressing power should turn tv back on if not repeat previous steps untill you get the right code some tv models are not compatible with the rogers remote 3 and 4 button pretty much the same except insted of a setup button you have to press and hold tv and select at the same time untill light flashes 3 times press 9-9-1 then press tv button untill tv turns off press select to lock into place
