Question about Microwave Ovens
I replaced the handle of jenn-air jmv 8000adb microwave which was broken. It was working fine otherwise. While replacing handle, I noticed that there was not light coming from the bulb. After I finished installing handle, I closed the door, then noticed no current. Dead. I thought circuit might have tripped. But that was okay as well. I can not figure it out as what happened to it and what can i do.
  • Microwave Ovens Master
  • 19,396 Answers
Probably you tripped cables and blew the fuse. Check the oven door switch and replace the 20 amps fuse located behind the panel at the bottom of the oven.
Here the fuse: PS2163369
it is part 5 on diagram below:
Here all parts and diagrams for your oven.
Posted on Apr 16, 2009
Jenn air microwave JMV 916 BAS won't power up
The magnetron has probably shorted, and in rare cases the power transformer will fail, "but unlikely"
Mar 27, 2012 | Jenn-Air JMV8000 Microwave Oven
The latch that opens the door to my Jenn-Air model M170 microwave oven is broken. I need to repair or replace it.
If the point of damage can be glued together with good bonding and further re-enforcement , it can be strong to withstand pressure.
So remove the assembly to try this out before you think there is no way out but to replace with the handle assembly from the service center.
The other option is to get one from a scrapped set.
Oct 01, 2011 | Jenn-Air M170 Microwave Oven
No power in the microwave. It is as if you unplugged it. Is there an internal fuse in the unit? There is power to the unit. The unit shows nothing on the panel and when you open the door, no light comes...
If you look at the back of the oven there are usually small fuses or breakers back there. Check to see if that is the issue. Also if you haven't already make sure the wall outlet is functional.
Dec 14, 2009 | Jenn-Air JMC7000 Microwave Oven
Jenn air microwave JMV8208BA/CA turns on everytime the door is shut
faulty door switch something has reverse its function, moisture or a broken wire. get it replaced
Aug 16, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Dec 19, 2008 | Jenn-Air JMC7000 Microwave Oven
Need New Microwave
Is the interior flaking the only problem with it?
It can be sanded smooth and clean and dried thoroughly, then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, if you want to replace it, I would suggest contacting Jenn-Air Customer Care here and telling them your model number.
They can probably give you the model number of a new "drop-in" replacement.
Dec 12, 2008 | Jenn-Air JMC7000 Microwave Oven
Broken Handle on Jenn-Air Model M406 Under Cabninet Microwave
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Nov 24, 2008 | Microwave Ovens
Microwave Door Handle
If the solution below does not work for you, please reply back with your brand and model number so we can help you.
Otherwise, here are some generic tips:
Normallyyou have to separate the door panels (as shown in the attached photo)and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Aug 01, 2008 | Jenn-Air Microwave Ovens
Microwave totally shuts off by itself
My microwave is under warranty. I have this problem before and it was "fixed" one month ago by replacing a thermostat. This repaire is under warranty for 90 days.
I will have a service man to look into this problem.
Thanks MK
Jun 29, 2008 | Jenn-Air JMV8196 Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
