Water will not stop running
The problem I have is, the water will continue to run while it spins and it will not stop unless I turn the water off.
  • 6,784 Answers
Hi, there is a water pressure sensor located on the water valve assembly. this sensor is malfunctioning. i would make sure that the water valve Assembly's wire connectors are not corroded and the wires are attached. if the wires are ok and the contacts are not corroded, replace the water valve assembly.
Please rate and god bless:)
Posted on Apr 16, 2009
My Karcher 530M runs ok until I release the trigger, then it will not start again unless I switch and allow the water to run through for about 15 secs before switching on again
Hi Cliff:
My experience is that the pump pressures prevent the engine from starting, so we hold the trigger while starting.
My brother has cut a wedge of wood that he uses to jam the trigger open to bypass the problem. It can get a bit wild if the wand is not secured when the unit is started..
Aug 10, 2016 | Karcher Garden
I have a 98 chevy cavalier and when i turn it on my engine fan spins but then stops.. but i have seen other car when they started the engine their fan keep up spining. why does my car does that?
is your car overheating???the fan isnt suppose to run when started(unless engine is hot), it may turn on then shut off. See if it runs when the vehicle gets hot and the A/C is on. Those engines with fans that move all the the time are belt driven. This is why they spin continually.
May 04, 2010 | 1998 Chevrolet Cavalier
Water overflowing and never shuts off
Jammed solonoid valve open position.....
Nov 02, 2009 | Frigidaire FWS1233F
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
Water want stop running on Maytag top load washer wit power on .
This problem is caused by a faulty water level switch. It is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, pressure increases on the air in the tube. When the pressure reaches a certain level, it activates the switch to turn off the water and signals the timer to start the agitate cycle. Look for any obstruction or defect in the tube. The switch can be checked for continuity with a multimeter. If it has no continuity the switch is defective. Hope this helped and best wishes.
Aug 03, 2009 | Maytag PAV2300 Top Load Washer
Hot water running into washer continuously.
Yes there is it is the water valve the part that your hot and cold water hook up to.You will need to replace that part Hope i helped:)
May 11, 2009 | Washing Machines
Cold water runs continuously at end of cycle
If yo9u were to unplug the machine at that point and the water continues to run in you have a bad water valve. If it stops when yoou unplug it, it may be the timer. Would have to test to see if voltage is present at the valve in the second scenario,. Water valve part# is WH13x10024 @ $51.00
Apr 08, 2009 | GE WJSR2070B Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
