Question about Dryers
The unit runs but no heat.
My Kenmore model 11070802990 gas dryer was working fine yesterday. Today the dryer appeared to be running normally except the burner didn't fire up -no heat. I checked the settings -all are set as it was yesterday when I had heat. I checked the power and gas supply -both are on. ???
  • 659 Answers
Your limit switch has tripped. You will find this small switch near the burner that is the size of a dime. Press the small button between the wires firmly to reset it.
Posted on Apr 17, 2009
    Problem Solver:
  • 7 Answers
Flame sensor is broken
I am trying to determine the age of my Kenmore gas dryer- Series 80 model 11070802990 ser MK 1715724
There is a web site, appliance411.com, which helps to identify the age of major appliances. I have gone there and looked up your dryer, it appears to have been manufactured in April of 2000.
Aug 02, 2013 | Dryers
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
I smell gas when the dryer is running but not when it is not running. Is this normal?
No not normal. Have this checked out thouroughly for leaks. More specifically around the dryer coils and gas valve. Check the burner tube for rust holes. Any holes in the burner tube and it must be replaced.
Sep 17, 2010 | Kenmore Dryers
Dryer runs but no heat. changed thermal fuse and still no heat. what else could it be and how do i get to it. i have a kenmore model #11070802990
hello 1 of the heat sensor could be faulty these sit behind the element usually right the back of the dryer there may be 2 of them if so change them both good luck
regards
shaun
Aug 03, 2010 | Kenmore Dryers
Kenmore gas dryer mod.110-73942. burner comes on as normal. After 5-10 minutes running Cycles off, igniter ( new) glows but no burner ign. Also replaced the sensor adjacent the igniter.
The gas valve coil is bad. When the ignitor is glowing the gas valve should open and allow gas in to be ignited. Change the gas valve.
Aug 05, 2009 | Kenmore 63942 Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Gas......starts to heat then quits minutes later.
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
Part number 279834 replaces for most models.
May 15, 2009 | Kenmore 62602 Electric Dryer
Kenmore gas dryer problem need help please
hope this help U
http://repair2000.com/norun.html
was this helpful?
May 11, 2009 | Dryers
Kenmore elite gas dryer won't fire up
replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
239 people viewed this question
Top Dryers Experts
