Question about Activision Shrek The Third for PlayStation 2
Cannot get through level 2...everytime i go to chest or wood it says press square but it does not open, a square in a yellow fireball thing comes up...what does this mean
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Are you sure it's square? Because with the display I get confused when it shows square or circle, you may be pressing the wrong button
Posted on May 08, 2009
It means to continue to push the x button to force it open
Posted on Jul 24, 2009
How do I retain the "cedar chest smell" from an antique Cavalier cedar chest. I have sanded with a steel wool product, but no luck....Help me get the smell back I'm looking for. Please.
If you refurbish the outside in any way it will loose value and appeal. The smell you are looking for is chamfer wood. You can purchase strips of this wood on line. Lay them at the bottom of the chest and enjoy.
Sep 19, 2014 | Cars & Trucks
Why is there a lot of frost in my woods v15nab freezer?
On a chest freezer, frost always accumulates around the top perimeter first because the warmer moist air comes in contact with that area first once the door is opened. More frequent defrosting may be the answer.
Jun 08, 2014 | GE Freezer  14.8 Cu. Ft. Manual...
Order a freezer basket for a chest freezer
wc Woods is out of business however sears.com lista woods parts. Good luck.
Apr 02, 2012 | Woods Chest Freezer C1501W3
Power Light On Woods Chest Freezer
blown globe or neon would not bother dont need it
Jul 18, 2010 | Freezers
What is the difference between a slotted round and square screwdriver?
A slot screwdriver may be used for screws with a recessed single groove that stretches across the head of a screw. A square ended screwdriver was invented in Canada by a man named Robertson. These types of screwdrivers are named after him and come in different sizes from 0, 1, 2, 3 and have different coloured handles, yellow, green, red and black to mark the sizes. Number 2 (red) is the most common for wood screws. Square drivers make better contact then slotted ones and don't strip the head as quickly.
Sep 30, 2009 | K-D Tools 1/4" x 4" Square Blade Slotted...
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
How to format low level format
You can download a software named Disk Manager from Seagate website and then write the program on to a CD, boot the computer using a Windows 98 bootable cd and then insert the Disk Manager and open the program, you will get the options to low level format
Rergards
Ajesh,
Professional Virus Removal Expert
Jun 19, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Cake Mania October Casino Level Stuck
You need to calibrate your touch screen...Follow these easy steps to do so.
1 Turn your DS on.
2 When you come to the main menu that lists pictochat, ds download play, and the game that is inserted in your DS, Tap the little ICON of the ds towards the bottom of the screen.
3 There should be a new menu that comes up with different colored squares. The yellow square has an odd icon with a box thing. Press this.
Follow the instructions from then on...
I hope this helps!
Jun 18, 2009 | Majesco Cake Mania for DS
- All Songs Cheat Code? Rock Band.
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } You might be playing the rythm a tad off. Try to keep it at the same pace pretty quickly without stumbling.
The rythm should be pretty quick. Like eighth notes or sixteenth notes if you're musica
Jul 20, 2008 | MTV Games Rock Band for PlayStation 2
Activision Shrek The Third for PlayStation 2 Logo
107 people viewed this question
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
dj ese
Level 1 Expert
James Wishart
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
