Question about BenQ T701 TFT 17" LCD Monitor
Power ok but No Display
I have power going on my monitor. the green led is on but nothing appears on the monitor, no flickers nothng at all even I tried to see wheater there is a problem with the screen light but nmothing at all. The monitor is receiving signal cause when I switch off computer the power LED will chnage its status to orange. Any help will be appreciated Thanks Liam
  • 26 Answers
See this one
http://www.fixya.com/support/t155971-benq_t701_lcd_monitor
Posted on Dec 12, 2007
2 Suggested Answers
djnupi
  • 26 Answers
SOURCE: Monitor
see this post
Posted on Dec 16, 2007
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
FIX THE COLOR, IT HAS A GREEN TINT THAT DOESN'T GO AWAY WHEN TRYING TO ADJUST COLORS FOR DISPLAY DON'T KNOW WHAT CAUSED IT
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jan 19, 2015 | Sony BRAVIA KDL-40EX523 40" LED TV...
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
ORANGE FLICKER ON POWER LED
Is the orange flicker on the screen or on the button?
Does it always stay on or does it go off?
What kind of monitor is it? Flat screen LCD or CRT?
Mar 23, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Monitor
Hi Abadir, It really sounds like your back light has bit the dust. I can't always see stuff on the LCDwhen the back light is out. Check in with LCDrepair.net for parts, and repair of your monitor. I truly hope this helps. Good luck.
Oct 09, 2007 | BenQ T701 TFT 17" LCD Monitor
Screen not appearing straight away
It could be your LCD backlight giving you problems till it warms up. Turn you computer on and while the monitor is displaying black and the power LED is green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. A 15" LCD monitor is probably not an economically repairable problem unless you have access to really cheap parts and have the skills and tools to do the repair yourself.
Jul 29, 2007 | AOpen F55PS (Black, Silver) 15 in. Flat...
Blinking Light
This is the same problem with my 4 VG800 Monitors, you should be able to find the correct capacitor on your monitors by following the same procedure, I'm sure the boards are similar. Just get the correct value capacitor and try it in parallel with the initial filter capacitors right after the DC power in.
Alright, I had 4 VG800 monitors with the exact same problem. The front led is blinky OR constant reddish/orangish OR picture is white with colored vertical lines OR no picture with whistling from the back of the monitor and backlights illuminated. All problems have the same solution. You need to disassemble the monitor (2 screws on the back, remove lower front button panel, remove 2 screws holding panel in and remove speakers, then remove panel and unplug speakers. Now remove lots of tape and screws from the cover in the center of the monitor). Now that you've exposed the amplifier board and the VGA to LVDS board, you want to look for the pair of 25V 100microfarad capacitors that are nearby the DC power in (they are right next to the black "100" inductor). Desolder the capacitor farthest from the DC jack and replace with an electrolytic with the same specifications. If you want to check that this is the correct solution please put the new capacitor (WATCH THE POLARITY) in parallel with the capacitor there want watch the front panel indicator go green and the monitor work properly.
I'll be posting and Instructable entry in the next few days on the process, watch for the username Waterppk on the website www.instructables.com
-Chris
Dec 11, 2006 | ViewSonic VX910 19" LCD Monitor
BenQ T701 TFT 17" LCD Monitor Logo
244 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
