Question about GE ZICS360NMRH Monogram® 36" Built-In Bottom-Freezer Refrigerator (ZICS-360NMRH, ZICS 360NMRH)
GE Monogram ZIRS36NM 36'' All refrigerator Drain tube location
I believe the drain tube is blocked. The pan below the refrigerator is dry and condensate accumulates and runs out the door. This is a built in. The equipment is above. Below is a the pan and some coils . Where is the drain tube located?
  • 1314 Answers
SOURCE: locate evaporator condensate drain tube
next remove the evaporator fan cover and under the evaporator will be a silver tray with a hole in it this is the drain for the defrost systems and some times they get frozen the best way to clear them is with a eureka 350 hand held steamer you can get at Lowe's fairly cheap you can also find about 1000 other uses for it a round the house
Posted on Jan 26, 2008
freetek
  • 5568 Answers
SOURCE: GE built in Fridge does not defrost and freezer ices up
Defrosters are commonly controlled by a primitive timer and this may have a 'dry' and a 'wet' (humid) climate setting that will cause the defroster to cycle generally every 12 or 24 hours.
If set wrong (by accident or on purpose), it can allow too much frost to accumulate before attempting to defrost.
This can cause a gradual buildup of ice.
Also the heating element for the freezer may have failed open so it never heats at all. The connections that need to be checked are often buried between the in- and outside walls.
The timer is probably still OK since you apparently aren't having a problem on the refrigerator side.
Posted on Jun 10, 2008
  • 148 Answers
SOURCE: GE refrigerator tfx27zp or 25zp or 22zp not sure.
The drip pan is located under the front of the frig.
FIX
open both doors, remove the panel that is across the bottom of the fridge( there are release tabs over the left and right front corner areas close to the hing sides
after removing the panel you should see a tray that slides on rails under the fridge
remove the panel and inspect to see (use a flash light)if you can see the drain tube
I believe your drain tube is freezing up somewhere inside the frig
If you can determine where this drain tube fishes up through the back inside wall of the frig
remove all of the trays and observe the back panels there should be some type of collector tray
near the frig light Some models have a hot bulb to do the defrost
I suggest that you tun frig off with both doors open take a hair dryer and blow hot air where you think the drain is located to melt any ice and look down in the drain pan to see if it starts draining
Hope this helps
Good luck ( ps cal ge customer service and give model number I bet they have a design poblem
If they do they may have a work around
God Luck
Posted on Jan 05, 2009
  • 117 Answers
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
VtToolMan
  • 704 Answers
SOURCE: 42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Posted on Jul 13, 2009
Ge monogram refridgerator water on floor
Is the water filter located behind the grille under the doors?. I had the same problem and found the O ring on the filter cartridge was leaking.
Dec 17, 2015 | GE Refrigerators
My monogram refrigerator leaks water from the upper left side/top of the freezer.It is a model ZIS- 42
you have a blocked/frozen evap drain tube leading to the pan, located directly above the freezer section. in all honesty donot believ this to be a repair homeowner should attemp i would contact an authorized ge servicer.As a maytg/ whirpool servicer myself , i know in our built in refigs we have new heated drain tube/evaporator pans that we installe possible that GE has as well
Mar 14, 2008 | Refrigerators
Replace monogram door gasket
alot of these gasgets are push in's. if u do not see screws when the gset is pulled out alittle then it is one that u just pull out and push back in.if there are screws behind gasget then u will have to lossen srews and work in new gasget.google model no. for correct part god luck
Apr 10, 2013 | GE Monogram ZIRS36NM 36'' Stainless All...
Ice build-up at bottom of GE Monogram refrigerator. Ice melts and leaks onto floor. How do I resolve this problem?
The drain hole is blocked, so water is not drain and getting freezed, and then melting and it leaks.--------the drain is stopped up ,, remove the inside back panel inside the freezer and pour hot water into the troft under the coil in the back and flush the drain ,, once water runs though the drain hole then put the panel back in and it will be fine.
The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. You can take the sheet metal cover off the back, get a turkey baster and flexible tube, and continuously flush hot water.this will clear the clog.--------- Thanks.
Sep 13, 2011 | Refrigerators
Cannot find the drain hole in freezer compartment
Defrost the frige by unplugging it and let itsit for 6 hours open. remove the icemaker and rear panel inside freezer. drain is in the middle below coils. Look on the back of frige for the drain hose to help you locate the drain. It is hard to spot covered with ice but it is a hole about the size if a dime. Pour hot water thru the drain. It should drain down the tube to the bottom drain pan...
Mar 29, 2010 | GE Monogram ZICS360NRRH C... Bottom...
GE Profile with water leaking. Does not seem to be a slow leak. More like an intermittant "dump." Water on floor and refrigerator shelves. Thanks!
Look under the refrigerator and locate the defroster water drain pan. There should be a tube running down the back of the refrigerator which drains water into this pan.
If this tube or other parts of the defroster drain system gets blocked, water can get diverted before it reaches the drain pan.
Oct 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Aug 25, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Apr 09, 2009 | GE Monogram ZICS360NR Bottom Freezer...
GE zir36n rh Monogram 36" built in refrigerator
I finally got my refrigerator fixed after three years of complaining. The units are set up to have the fan running even if the cooling unit is not currently on. So when the unit is not cooling, then the fan is brining in moisture from the outside air which causes the water/mold. GE repair rewired the fan to run only when the unit cools on 4/20/10 and it has fixed my problem!!! Of course, this was only after I have thrown out a LOT of food!
Oct 03, 2008 | GE ZICS360NMRH Monogram® 36" Built-In...
Refrigerators Logo
434 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
