Question about Dell Dimension 3100 PC Desktop
Dell dimensions 3100
Hi! my computer doesn't start normally it goes back to the same error every time.
Errors:
Floppy diskette seek failure
Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave)
Strike the F1 key to continue, F2 to run the setup utility.
I tried to get into BIOS setting and F1,F2 settings every thing looks fine, but still my system doesn't start.
Please help.
Thanks
    Problem Solver:
  • 9 Answers
When in BIOS, try to go to the BOOT section. I know it's there, and disable the BOOT ON FLOPPY DRIVE. If my guess is correct, this model doesn't come with a floppy drive in the first place. Once you find it and change it, select EXIT, in that screen select SAVE AND EXIT. and it should reboot the system. If you still get the error, carefully look in the bios for anything regarding the floppy and disable it. Make sure to save your changes before you leave BIOS.
Posted on Apr 20, 2009
  • 298 Answers
Sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Posted on Apr 16, 2009
My dell c521 says diskette drive 0 seek failure
You need to press f2 then go to Standard CMOS Features, then highlight drive A. Change it to none. You should not have anything in there enless you have floppy drive
Jan 14, 2014 | Dell Dimension C521 PC Desktop
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
My computer keeps reading diskette 0 seek failure on a black screen and wont start how do I fix this issue. I have a dell desktop computer
You might get this error if there is a non-bootable diskette in the drive. Remove it if so and you might have a normal star-up.
If there is no diskette in the drive, you may have a hard drive failure where the computer can't start normally and is switching to try the floppy.
Apr 13, 2013 | Dell Vostro 200 PC Desktop
Diskette Failure F1 to continue or F2 to run setup??
Your computer is looking for a Floppy diskette drive. If you entered the BIOS ( setup menu ) and selected default settings to be applied it selects the first boot-table drive as the floppy diskette drive. You have to disable the floppy drive if you don't have one.
Sep 06, 2011 | Dell Dimension 3100 PC Desktop
My dell dimension 9200 is booting and then giving me a Floppy Diskette Seek Failure message. What is causing this to appear and not boot windows 7?
Hi. You computer seems to be booting up using the floppy disk and your floppy disk drive might not be connected properly, not working or not even there. Press F2 to run the setup utility and disable the floppy seek in the bios. It will most likely be in the "Advanced CMOS setup" area, or the 2nd screen depending on your bios. look for "Seek floppy drive at boot?" or, "Disable floppy seek at boot?" or something like that. When you find it, make sure it's not enabled for the seek. Save the change on exiting. :-)
Jun 05, 2011 | Dell Dimension 9200 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Boot up screen says "diskette drive 0 seek failure"
Press F2 look through the menus and remove / disable 3.5 floppy drives.
Jan 06, 2010 | Dell Dimension 8400 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to continue,...
Press F2 to enter the Bios, on the first screen navigate to the floppy A: drive select disable and the error should go away.
From the sounds of it your Floppy drive is damaged or just bad. you can take it for repair or purchase a new one fairly cheap and replace it yourself. But just disabling it should do the trick since floppy's are pretty much obsolete.
the recovery Disk wont help you unless its an error you get in windows itself btw.. (unless its a OS start problem which this doesn't seem to be)
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
Dell Dimension 3100 PC Desktop Logo
390 people viewed this question
Alun Cox
