Question about Canon ImageRUNNER 1670F Copier
Where is the fuser area in the Canon D860? - Canon ImageRUNNER 1670F Copier
  • 1 more comment
  • mrsrayman Apr 16, 2009
    I am getting a black streak across the right edge of my paper.
    The previous posting recommended cleaning the fusers.
    How do I get to them.
  • mrsrayman Apr 17, 2009
    Are the rollers visible or do I need to take a part a portion of the machine?
  • Arthur Hoffmann
    Arthur Hoffmann May 11, 2010
    The fuser is ALWAYS after the Photo conducter. What is the problem with the copier?
  • 469 Answers
The Fuser is the heated section of the machine, the last process before the copy leaves the main portion of the machine.
You should find two rollers, upper and lower, if these rollers are unable to clean themselves excess toner will build up on the rollers and get passed on to copies later on. you can clean these rollers with some alcohol or similar solution. Be sure the machine has been turned off for awhile as these rollers are extremely hot when at operating temp.
The second question would be, why is the system not cleaning itself. Sometimes if the copier has been on a large run with a lot of dark areas it can overwhelm the cleaning unit, but if this is not the case you will need to determine what is wrong. The Fuser is usually cleaned by a cleaning roller, cleaning web or cleaning wick.
These cleaners are usually white when new, brown to black when well used.
They are usually oiled with a silicone oil which prevents the toner from sticking to the Fuser rollers, so the cleaner may not look too dirty but may be out of oil.
This may be a part you can change or you may have to call in a Tech.
Hope this helps.
Posted on Apr 17, 2009
  • Ed
    Ed Apr 17, 2009
    I am not completely familiar with the Canon table top machine, but looking at the product on the Canon web site I would look also at the image unit /toner cartridge, Has it been replaced lately?
    Check for paper caught in the unit, Or any other sign of excssive toner on one end.
    The fuser is usually covered by a heat shield, but if you remove the exit tray and look into that end of the machine, you should see two rollers that run full width of the page. This section should open to allow jam removal, if so open this section to expose the fuser. If no open the Jam clearing area and see if the rollers are accessable.
    Hope this helps.
    Ed
3 Suggested Answers
shoeria
  • 40 Answers
SOURCE: CANON D860 copier display error message E0000
...usually the problem is in the fixing unit...
Posted on Jul 09, 2009
canontech
  • 1219 Answers
SOURCE: paper keeps on getting jammed on my canon d860
if you change the fuser asy by the book it goes about 80000 to 100000 copies.
If you only change the fixing film if it isnt goodly adjusted and if there is also problem with pressure roller then that would not be a good idea.
Im telling you these without seeing the machine or without knowing your monthly volume of copies.
These is small volume machine for "home usage", if you want quality and better machine buy Canon ir 3225N. These is serious office machine, with extended parts life.
Hope that helped!
Posted on Jul 29, 2010
Paper jammed at exit rollers of Canon D860. Paper
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
May 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
System error E000
  • Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer"
  • Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
  • Then press "Set" again, and the display will ask you "Yes" or "No"
  • Press the "Left" arrow for "Yes", then press "Set".
  • Now, unplug the power cord and wait 5 seconds and plug back in
That should clear the error. If it doesn't, get a new fuser.
Feb 29, 2008 | Canon imageCLASS D860 All-In-One Laser...
System error E000
Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser.
Feb 14, 2008 | Canon imageCLASS D860 All-In-One Laser...
Sounds like there is a papper jam but I can not see papper. Copies are coming out crumpled.
These machines use a fuser film. When they get torn or go bad they make a paper crumpling sound. When this happens it also causes wrinkles and creases in your copies. There may also be areas of your copy where the print will rub off. This means it is time for a new fusing unit. They are not cheap and removal of the old unit and installation of the new unit is not easy so plan on having a service person replace it. Just do a search for Canon D860 fuser or fusing unit.
Good Luck and Thank You for using Fixya.
Apr 30, 2010 | Canon imageCLASS D860 All-In-One Laser...
What's the procedure for replacing the fuser on the canon imageclass D860?
Hi Un-plug it first I Have changed many. You need a very small No 2 phlips screw driver like 1 inch long and a regular no 2. First you take the covers off the left side. I think its about 3 or 4 pieces. Look under the black plastic sheet and you will see the fuser. Using your small screw driver remove the the screws holding it in. Un-plug the connectors and pull it out slowly right side first. The thing that goes bad is the fuser sleeve. The replacement to use is the HP laserjet 4000. It should cost about 20-30 $.
Jan 21, 2010 | Canon imageCLASS D860 All-In-One Laser...
HOW DO YOU CLEAN A CANON D860 COPIER?
your fuser rollers are dirty and tracking the image
unplug the machine open the fuser area wait until they cool down
take fuser oil(silicone lubricant) and wipe the rollers
while you are at it remove the glass and clean the reverse side and clean the mirror and lens
take a q tip and ubbing alcohol and clean the charger wire
Dec 30, 2008 | Canon ImageRUNNER 1670F Copier
Replacing fuser pc1610
Please let me know if there is a technical reference or service manual for the PC1060 (including Image Class D860) printers.
MXM450, Please let me know how to replace the fuser. I have spent an hour trying to get to the fuser but am not sure if it is from underneath the feeder assembly, or through the toner cartridge door.
Oct 04, 2008 | Canon PC1061 Copier
Canon Copier D860, Serial# KAB50221, Received on 1/24/06
if under warrenty you'll defanetly want to send it back,usally when i see this the fuser nees replaced
Sep 18, 2008 | Canon Office Equipment & Supplies
Need Help Please
problem w/the fuser, probably the lamp is not turning on and not heating the rollers, need to change.
Jun 02, 2008 | Canon imageCLASS D860 All-In-One Laser...
Canon ImageRUNNER 1670F Copier Logo
529 people viewed this question
old marine
old marine
