Question about Dell Dimension 3100 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to continue, F2 to run the setup utility. I tried to get into BIOS setting and F1,F2 settings every thing looks fine, but still my system doesn't start. Please help. Thanks
  • Timothy Farley May 11, 2010
    Hi there. Do you have a Dell recovery disc? You should have got one when you bought the system.
    Problem Solver:
  • 13 Answers
Enter cmos setup and turn off floppy drive seek. also, disable floppy drive. then save your changes and exit.
Posted on Dec 22, 2012
  • 298 Answers
Press F2 to enter the Bios, on the first screen navigate to the floppy A: drive select disable and the error should go away.
From the sounds of it your Floppy drive is damaged or just bad. you can take it for repair or purchase a new one fairly cheap and replace it yourself. But just disabling it should do the trick since floppy's are pretty much obsolete.
the recovery Disk wont help you unless its an error you get in windows itself btw.. (unless its a OS start problem which this doesn't seem to be)
Posted on Apr 16, 2009
The floppy disk or drive is damaged, or if your trying to boot your computer and you have a floppy in the drive that is not bootable. It will try and boot from floppy first then cd then hard drive usually but floppy's are stupid and only return an error and then stops. Remove the floppy disk and boot
Dec 06, 2013 | Dell Dimension 5100 (D51L1) PC Desktop
My computer keeps reading diskette 0 seek failure on a black screen and wont start how do I fix this issue. I have a dell desktop computer
You might get this error if there is a non-bootable diskette in the drive. Remove it if so and you might have a normal star-up.
If there is no diskette in the drive, you may have a hard drive failure where the computer can't start normally and is switching to try the floppy.
Apr 13, 2013 | Dell Vostro 200 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Diskette drive 0 seek failure
Does the PC have a floppy drive? If it doesn't It appears that your BIOS (Basic PC setup) thinks that there is one! I think that pressing f2 on boot will bring you into the BIOS setup.
In there, see can you locate any reference to 3.5 inch floppy and amend it to the setting which suits the config of your PC.
Please take care as to what other settings you change in the BIOS
If you find this sugestion helps please take time to rate it
Aug 30, 2008 | Computers & Internet
Floppy Diskette Seek Failure
1st-replace the ribbon cable for floppy, see if that works,2 nd replace floppy
May 02, 2008 | Dell Microsoft Windows XP Home Edition
Dell Dimension 3100 PC Desktop Logo
262 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
