The ?OE? indicates drainage trouble. It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Was this helpful?
Yes
No
Popular Solutions for LG 24 in. LD-12BS6 Stainless
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG LD12AW2 DW contiunes to fill and I can't fo the life of me locatse the filler float assy and...
(More)
LG LD12AW2 DW contiunes to fill and I can't fo the life of me locatse the filler float assy and switch even though I have a schematic. Chris
I have the same problem OE error code. I pulled everything apart. I have checked pump,lines and all...
(More)
I have the same problem OE error code. I pulled everything apart. I have checked pump,lines and all clear. What tells the controller that its empty? The only sensors I can see are the temperture one above the heater and a flow meter which uses a magnetic pickup but this is on the inlet side. Any ideas?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
