Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Release spring popped off when dumping the cannister.
Now the bottom just hangs there and won't attach. I have the black piece and the spring, just can't figure out the orientation.
  • Vanessa C. Dudoit May 26, 2013
    Spring not by canister ,spring is the one that releases the back wheel to push vacuum forward
  • 61 Answers
As long as the black piece still has the "nubs" on both sides at the turn in the "L" shape and the base isn't broke then this is going to be easy. There is a groove on the main unit the little wheel fits into that groove, the "nubs" fit into small holes on the swivel down piece, and the spring fits between the small side of the "L" shape and the bottom of the swivel down piece.
Posted on Apr 17, 2009
Easiest way to attach spring to the back wheel base?
As long as the black piece still has the "nubs" on both sides at the turn in the "L" shape and the base isn't broke then this is going to be easy. There is a groove on the main unit the little wheel fits into that groove, the "nubs" fit into small holes on the swivel down piece, and the spring fits between the small side of the "L" shape and the bottom of the swivel down piece..
May 26, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
I can't get the bottom of the canister to open in order to empty the disrecarded material.
Remove the cannister from the vacuum. The bottom lid should release if you depress the red button at the top of the cannister, if this does not release the bottom lid, you will have to depress the red button while pulling the lid open. Either the release mechanism need repair or there is something jamming the bottom lid.
Let me know if you have any other questions. Thanks.
Nov 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kenmore PowerMate cannister: Reattach cannister floor piece.
You need to open the head by gently squeezing the light cover housing and lifting it off. There will be two screws underneath and once removed the lid will lift off and reveal the area where the pedal installs.
Sep 02, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Pulling up on button will not release bottom of cannister.
The gasket is sticking to the dump lid. While holding it over a waste receptacle, operate the release button and pull the waste gate at the same time. Rinse the canister and dry thoroughly. Apply a spray of silicone to the gasket surface, let it sit for a minute, and wipe off the excess with a paper towel. This should fix you up.
Best regards, --W/D--
Aug 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC-07 Hose Wand Spring Came Out. How to put back in?
You'll see that there is a round piece with a cross shape on the inside of the button wand release button - place the end of the spring over the cross - you'll see the same cross on the collar of the machine...it'll take some doing, but line the other end of the spring up with the cross and pop the button back into place - be sure to click it onto those two gray circular/oval shaped divets at the bottom where the release button connects to so that the button stays in place.
Jun 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Feb 21, 2009 | Electrolux Epic 6500 Vacuum
I have a Kenmore Wispertone 300 cannister and I am trying to access the motor. There are four screws shown in the parts diagram. I need to remove the plastic on/off pedal to acess two screws. How do I...
I just encountered the same problem on a Whispertone 116 last evening. If it is the construction same as mine, there are four flexible plastic retainers molded into the top cover in the gap between the pedal and the motor cover. These are on the hinged side of the pedal. All four retainers must be bent in toward the interior of the vacuum simultaneously to release the pedal. A screwdriver does not work very well for this. What worked for me were four metal bars about 3/8" wide X 1/8" thick X 1-1/2" long. The pieces I used were actually the snap-off ends of some hanging file rails I found in my basement. Insert the four bars at the four retainers. They should fit snugly as they must push the retainers past the hinged portion of the pedal. To remove the pedal, rotate the pedal up in the same direction as the spring is pushing and it should come free from the motor compartment cover at which point you can access the other two screws. I suspect Sears has a special tool with four tabs to perform this trick in the repair center. Good luck!
Jan 03, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Round filter clogs often
The Flange in question is about one inch tall and and approx 4 inches circular ..... When you pull the canister (container to empty) off and empty the contents in the trash .... some of us tap it to get the excess out or off the sides ..... That Flange is the rubber piece attached to the bottom of the darker gray cylinder inside the canister you are emptying. When you tap the canister or after dumping it numerous times that flange can work itself (slide) up the darker gray cylinder ...... it needs to be slid downward and overlap the bottom when you close the canister from dumping it. You can remove the flange and see the grooves .... replace it back on with it hanging off a little to allow for overlap. That should decrease the amount of excess being trapped in the filter. Hope this helps.
Jul 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Wont release liquid or shampoo.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=601973
Won’t release liquid or shampoo.
Posted by lilmrsmcd on May 16, 2008
I have a Bissell Pro Head 2X Steam Cleaner Model # 9300-C
The little plug at the bottom of the bad for clean water came apart and would not let water out now won’t hold it in.
Inside is a little propeller a spring a washer and a little black plug. Flat on one side and beveled on the other. We have tried to put it back in various selection and cant fix it please help ASAP liquid bladder will not release water.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. On the little black plug – they do wear out and need to replace it but use a genuine Bissell part when replacing the part other wise a replacement may not work. Q. #2 the little propeller spring usually is part of the solution tank and it is wise to replace the part with a new or a good used tank from Bissell, so check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
164 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
