Question about Nikon Coolpix S210 Digital Camera
I have a Nikon CooolpixS210 and for some reason my camera randomly says "lens error" when it was worling fine earlier today. I have had no problems prior to today, if anyone has a soultion please let me know.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Aug 26, 2012
2 Suggested Answers
SOURCE: lens error
This may be related/helpful: My S3 in normal home use (no sand, wet or shock) just now displayed the ?Lens cover error? message, with cover only half open. Using a tooth pick I ?eased? it gently and it popped open, took a few trial pictures- fine, but would not fully close unless eased. Now will open and close slowly on own but error message blocks camera use. Then spotted cause - a loose thin sliver of silver trim from below flash around (there?s a gummy substance where it should be). When I first saw one end of this it was between the lens cover and the camera body as tho part of the mechanism, so I did not touch it. Now I know it?s jamming the lens cover operation is it OK to open the camera case to get it out? Questions: (a) Has anyone done this please? (b) Will this clear error message? Thanks.
Posted on Sep 25, 2007
How can I repair the lens error message on my Nikon Coolpix S6800 camera?
Copied from Nikon's Service & Support Page:
Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge the battery. Retest.
If this does not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras.
To find your local Nikon authorized service agent Click Here.
We apologize for the inconvenience and will do everything we can to repair your Nikon camera as quickly as possible.
Apr 24, 2015 | Nikon Cameras
DSLR says lens not attached
Hey there,
It sounds like your problem is related to the aperture setting on your lens. The aperture ring should be set to the smallest aperture usually f22 when attaching these older lens. Most lens aperture rings will provide a locking mechanism for that ring on the lens.
The aperture would be then set through the camera, not on the lens. Also some nikons have a lens preset on their menu, where you can inform the camera which lens is attached. Most of the older lens lack any terminal points for communicating with the camera automatically, therefore you will have to fill in the data manually to get better functionality out of the lens camera combo.
Sep 25, 2013 | Nikon D3200 24.2 MP CMOS Digital SLR with...
L18 lens error
From Nikon site...
Why does my camera show "lens error" on the screen?
Additionally, this link could helpfull: fixing-lens-error-on-digital-camera.html
Hope helps (remember to rate and commet this answer).
May 12, 2011 | Nikon COOLPIX L18 Digital Camera
Nikon Coolpix S550 Lens Error.. Need fix without spending
No, even if you could find a lens for free this is not an easy camera to replace the lens on. Even a qualified tech would take up to an hour to replace. Understand that today's cameras low cost makes replacing the camera a better option than repairing a camera who's value used is less than the repair cost.
Jul 03, 2009 | Nikon Coolpix P1 Digital Camera
Nikon coolpix L18 lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 04, 2009 | Nikon COOLPIX L18 Digital Camera
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Apr 03, 2009 | Nikon Coolpix S210 Digital Camera
Nikon D100 randomly has "err" code flashing
You need a new shutter box.
It may be worth cleaning the contacts on both camera and lens.
Clean the contacts in the lens mount using a fiberglass "pencil" designed specifically for cleaning contacts. These are available at just about any photo supply store/firm.
send it to nikon. seem like a common problem
Jan 24, 2008 | Nikon D100 Digital Camera
Lcd reads system error
Apparently often related to a lens motor malfunction. My old 4300 just gave this error for the first time today. The lens extended but made a whirring noise before the message popped up. Nothing I tried would fix it - but after I drove home it worked fine again.
I had a similar problem over a year ago after the camera fell out of my backpack (it was in its own bag but not well padded). When I used it the lens stuck and refused to retract, but I don't recall a "System Error" message. After a few tries, the lens went in and it's been fine since, until today.
Make sure there's nothing (dust, dirt) stuck in the lens barrels. Otherwise, just keep turning it on and off and hope it works.
Dec 31, 2007 | Nikon Coolpix 4300 Digital Camera
System error
My camera has been sitting in a drawer since 2005, found it tonight and decided to try take it apart to see if the lens was stuck ( apparently this is a problem with nikon coolpix), but before i did ( couldn't find screwdriver) decided to try gentle brute force. i turned it on and off 6 or 7 times while banging on the body beside the lens (to the left if looking at the screen) and it seems to have worked. Systems Error message has gone and i've taken 20 or so pics. i was actually looking here for a solution earlier today, so here you go guys
Dec 07, 2007 | Nikon Coolpix SQ Digital Camera
Lens error
Aug 21, 2007 | Nikon COOLPIX S6 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
