SOURCE: How do I hook up a dell laptop to a 50
You can refer to 2 tutorials :-
http://www.techlore.com/article/10061/How-To-Connect-a-Computer-To-Your-TV/
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Thanks.
SOURCE: how do I connect a playstation 3 to my sanyo tv DP26648
try it on another set first to see if game or the set is the issue.
SOURCE: What could cause a 27" Sanyo flat panel dp26648 to lose picture, but keep sound?
There are two reasons why your Sanyo DP26648 would has sound but no image and both are equally likely in our experience.
First, you may have a problem in the section of the power board that supplies the backlight module (called inverter) with 24V.
We've seen that several times and the problem is usually minimal - only electrolytic capacitors gone bad - and other times not so minimal.
We have a repair service for that power board and we may have some boards available too...check out at
http://www.coppelltvrepair.com/search?Q=DP26648+&As=false&Pf=&Pt=&Sid=false&btnsearch=Search
