Question about Xerox Phaser 8560MFP Laser Printer
I HAVE A XEROX 8560 THAT I AM GETTING BLURRED PRINT WITH, I DID THE CLEANING CYCLE AND THAT WORKED FOR A DAY AND A HALF. NOW THE FIRST TWO PAGES LOOK GOOD AND ALL THE REST ARE BLURRED?
  • Anonymous May 21, 2009
    Intermitten blurred printing, followed the five FAQs and possible solutions, nothing worked....not sure Xerox knows what the problem is.
  • Xerox Contributor
  • 185 Answers
Oil from the drum has ran off over the drum encoder position sensor.
Take the right cover off and find the fan. Remove it and loosen the clear plastic sensor cover underneatch. Clean the sensor and generally with Isopropyl and Q-tip.
Clean the nearby wires and anything that might be transporting more oil back to your sensor
Posted on Jul 31, 2009
  • Blaine Transue
    Blaine Transue Sep 09, 2010
    wrinaldo...I'm not going to get too elated yet, but definitely tomorrow. While it wasn't easy based on the description to get to the sensor, I did manage to get this puppy apart and clean the sensor. I might add that it's the "film" that runs through the sensor that needed to be cleaned, and as you mentioned, any other pieces, including the backing that the film adheres to. In our case, I assume this happened when we moved our office and the printer was perhaps put in a compromising position, although I don't really know, since I didn't move it. There is one tricky bit, and that's that there appears to be an alignment mark on the film. Having not paid attention to it when I removed the film, I could only assume that the printer was smart enough to set itself to that particular position when I powered it down, and that the only logical thing to do was center the line in the the middle of the sensor when I put it back. Would love to know if that's indeed true, or if it does not matter. In any case, all of the test pages printed properly, and subsequent prints have so far been fine. Since I couldn't print anything prior to this that wasn't blurred, I'm going to cross my fingers and hope that this indeed fixed our problem. So, am I correct that the oily film simply throws the sensor out of what, so it basically doesn't get things "lined up" properly (lay man's description admittedly). Also, I notice that there is a light gray ring around the outer rim of the film...I assume it serves a purpose,would love to know what.
    In any case, thank you. It seems you earned that "guru" status.
Shadow Printing on a xerox Phaser 8560. Have changed the Maint Roller and done the various cleaning cycles
The printer requires a maintenance kit. (95% chance anyways)
I would suggenst the extended life maintenance kit (10,000 page lifespan) part number 108R00676 to correct this issue.
You can usually get these where you get your solid ink cartridges.
Feb 25, 2011 | Xerox Phaser 8560DN Laser Printer
My xerox phaser 8560 is printing muted color
First off on your screen access troubleshooting, and perform the remove light strips and also remove smears and skips.
Next go to Xerox.com, under support and drivers enter 8560 in the search box. then go to the support page.
You want to look up the procedures for TEC color correction. And follow those steps.
If you are using a generic ink then, all bets are off in getting true color reproduction.
Feb 10, 2010 | Xerox Phaser 8560DN Printer
Phaser 8560 not printing RED correctly
Even though Media Sciences ink is not compatable and is subject to burning and clogging your printhead, the most telling symptom you listed is the red shavings. This indicates the ink is not releasing from the drum properly. This version of solid ink has a problem with the cams on the maintenance camshaft cracking and this causes the maintenance kit roller to not oil the drum properly. You will also hear an odd noise either grinding, groaning or a slight tearing sound. This requires a technician to resolve as replacing the camshaft is not an enduser job. Print quality issues are either the printhead or related to the camshaft failing, there are a few others but they wouldn't exhibit the symptoms you listed.
Jan 11, 2010 | Xerox Phaser 8560N Laser Printer
My print jobs keep coming out with smears in certain spots and now the entire print job is blurred. I've cleaned it several times. How do I correct that myself?
If the entire page is blurred, it is probably a dying wave amp board. Time to start shopping because the repair bill is more than a new 8560.
Jul 08, 2009 | Xerox Phaser 8400 Laser Printer
Blurred Images
You don't need to remove it.
Remove the right cover, and the fan on that side. Partially remove the clear plastic cover of the encoder and go in with Isopropyl and Qtips.
Also clean the nearby wires and anything that could transport the oil
-Whit :)
May 14, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox 8560 outputs Cleaning Pages several times a week. The unit is never turned off and only goes into "sleep" mode. Last time it woke up at 1:00 AM and went through the noisy cycle and output the...
There is nothing you can do about the cleaning page. And if its only using 20% of your ink, you're luck normally its 25% of the ink. This is simply how the machine works. Nothing can be done. The Xerox employee was simply trying to give you something to try, but it won't change anything!
Mar 27, 2009 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560
On the right side of the machine. There is an encoder mounted to the end of the drum shaft. They are known to become contaminated with the silicon lubricant from the maintenance kit. That causes the drum to spin off speed somewhat randomly. You can take it off the shaft and clean it well with alcohol. Sometimes they need replaced, but if it is as intermittent as you are suggesting cleaning it should take care of your problem. Not all that uncommon.
Feb 07, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Jul 11, 2008 | Xerox Office Equipment & Supplies
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560MFP Laser Printer Logo
1,425 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
