Question about Estate TAWB600JQ Top Load Washer
How to open door
After the washer ran it's cycle, I can't figure out how to open the door. ??
  • sisy75 Jul 17, 2008
    I have Bosch Classxx1000 and all of a sudden the door stopped working after washing. Can you help pls
If the machine is a top load estate washer the mechanism that triggers the machine to agitate may be misaligned or broken basically blocking the door shut. I suggest a repair man as this mechanism is near the hinge on the machine and taking apart the machine while under warranty would most likely void the warranty.
Posted on Aug 31, 2008
Could be an electronic lock like my bosch. try waiting a minute or two then it may click unlocked.
Posted on Dec 22, 2007
From what I've heard... the machine has to go through at least SOME (like a minute or 2) of the dryer cycyle... then I've HEARD that the door will then be able to be opened.
Posted on Nov 19, 2007
    Sergeant:
  • 212 Answers
How did you get the clothes into the washing machine in the first place?
Posted on Sep 16, 2007
SOURCE:
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
Smells musty and not washing clothes well
"In washing in the HE washers I think that if you have more than 3 loads a week you should maybe wash your washer at least once a week. I have started wiping the door off and leaving it open between washing and that helps a
lot with the smell.
This is why I think if you could wash the washer once a week it would probably do better. You never had this problem in the old washers." Try this in your washer.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Mold and mildew in door. washed, cleaned, ran
the only thing you can do now is replaced the door boot seal. after replacement usually you have to leave the door open till completely dry or dy it with a towel after each wash
Sep 28, 2009 | Frigidaire ATF6000ES Front Load Washer
LG wm1814cw washer is leaking from the front
Did you check the door bellow. I know you said it's not the door but if you really open that rubber pull it back and check it from top to bottom. let me know I'll keep thinking.
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Amana Dishwasher door will not open. Latch you grap is very loose
We have the same problem and I bought the latch locally for $26.00 now trying to figure out exactly how to get the door apart to replace.
Dec 12, 2008 | Amana 24 in. ADB1500AW Built-in Dishwasher
Can't Open the Washer Door---Our Clothes are held Hoatage
Check and ensure that the tubes and passages to the water level pressure sensor are not blocked by caked detergent, lint , etc.
( this may have caused the water overflow in the first place)
clean up the internal parts that are wetted by the overflow.
clean the door lock mechanism. ( this normally works on a temperature delay mechanism, if cleaning does not work, replace)
all the above done with the power unplugged and water inlets unplugged , of course
Apr 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Estate TAWB600JQ Top Load Washer Logo
94 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Bobby G
Bobby G
Steve Allison
Steve Allison
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
