Question about Bosch 11241EVS SDS-Max Rotary Hammer
I have a bosch rotary hammer 11245evs and it was working when i put it away in its case, now it will not hammer. Drills ok. larry
  • larry unger Apr 16, 2009
    yes that is correct--i am not getting and hitting at all. it will drill but will not hammer with the selector on hammer. are they filled with oil ? thank you
  • Corey McConnell
    Corey McConnell May 11, 2010
    I take it you have changed the selector from drill to hammer and you are not getting any hitting?
  • 154 Answers
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Posted on Apr 16, 2009
  • 706 Answers
All grease packed hammers require a short period of time to warm up before starting the hammer function. Depending on the room temperature, this time may vary from approximately 15 seconds (90?F) to 2 minutes (32?F).
- and then be sure to turn the switch to position 3:
Hammering Only:
used for chipping and demolition work
- or:
Vario-Lock position is intended for use with chipping bits such as bull points, spades, gouges, etc.
Depress release button and turn the selector lever, to the "vario-lock" setting. Next, rotate the locking sleeve, along with the accessory, to the desired position. Then turn the selector lever to the "hammer only" setting and slightly turn the locking sleeve to have it automatically lock into a definite position.
i have a bosch rotary hammer 11245evs and it was - bosch-rotary-hammer-11245evs-l2syhiveb5h5n2hnqsepdito-2-0.jpg VARIABLE SPEED DIAL Your tool is equipped with a variable speed dial. The impact rate (BPM) and rotating speed (RPM) can be varied according to the type of work being performed by setting the variable speed dial to the selected setting
-check that also, perhaps it was moved during storing
Posted on Feb 07, 2015
My Bosch rotary hammer only go on reverse
hi
check the switch functioning if ok
then there is a broken or disconnected wire by the switch
May 01, 2017 | Bosch Drills
How do I replace brushes on this drill?
[PDF]Hammers and Hammer Drills - eBuild
www.ebuild.com/ImgRepos%5C2010%20Hammers.pdf_06072010_110..See pages 46-49,. 184-214 for hammer drill accessories. BOSCH. H a m m e rs a n d.... 11250VSRD - 3/4" SDS-plus® Rotary Hammer .... technician can quickly replacethe brushes and cord .... 11264EVS - 1-5/8" SDS-max® Rotary Hammer.
Oct 20, 2015 | Bosch 11264EVS 1-5/8 SDS-Max Rotary Hammer
Chuck not gripping drill bit
Most people who having the little bosch rotary hammerdrills do not use lubrication on the chisel.
and the chuck will notwork ing on only the ball because in most case of this the camshaft drive are worn out the locking sleeve.
Apr 11, 2014 | Bosch Drills
Bosch 11241EVS won't hammer
Not all bits for hammer drills are the same as the slots in the sides of the shanks are different between makes . There is a standard between hilti and ramset drill bits but other makers have different ideas Check out the shanks of your drill bits and look for the slot that holds in the bit.
May 26, 2013 | Bosch 11241EVS SDS-Max Rotary Hammer
What is wrong when the 11245evs drill starts smoking?
It could be that the motor isn't getting the proper current to run, causing it to overheat. Don't use long or low guage extension cords with this type of tool. If the brush holder is warped or the brushes are worn down so that they aren't making good contact with the armature the same condition could arrise. It's possible you have a short or broken wire in the armature or field that's causing it to arc and heat up. Another possibility is something wrong in the workings of the drill that is causing the motor to overwork and get hot. There are a LOT of parts in there so you'd have to take it apart and know what to look for as far as damaged or broken parts.
Jun 28, 2012 | Bosch 11245EVS 2Inch SDSMax Rotary Hammer
Rotary hammer 11245EVS - Rotates but does not hammer. Thank you. Glen
The motor in these rotary hammers drives two systems in the gun, one to rotate the bit and another that produces the hammering action. The hammer system is mainly a piston driven by a plastic connecting rod on an eccentric cog. The 'usual' failure is the plastic connecting rod but could be any of the gear pins or teeth. It is also possible the striker is stuck in the hammer pipe if the gun wasn't lubricated properly. There are over two hundred parts inside one of these tools so if you're not familiar with repairing one I highly suggest finding a repair shop that works on them. They are good tools and usually worth repairing unless a lot of major parts broke inside.
Aug 15, 2011 | Bosch 11245EVS 2Inch SDSMax Rotary Hammer
I bought a used Bosch Bulldog hammer drill on the internet some time ago and discovered it's not hammering. It will drill be almost no hammer action. Any suggestions?
There is an o-ring on the striker that will wear down over time, this needs to be changed, of worst case the striker has stuck in the hammer piston. Both these repairs should really be done by a service center as these hammer drills are complicated to repair if you are not familiar with them. Any Bosch service center will be able to help you. Just go to the Bosch website and find a center in your area.
Jun 08, 2011 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
Looking for lubrication info on Bosch rotary and demolition hammers. I am doing a service pack and need to know proper lubrication points and amounts to refresh my drills for work. Any place to find repair...
try going to Boschtools.com and you will need your exact model number but they have parts explosions with the grease points listed on most of them Let me know if you need more assistance.
Mar 06, 2010 | Rotary Bosch 11263evs 1-3/4'' Sds-max® ...
Hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Bosch 11241EVS SDS-Max Rotary Hammer Logo
1,967 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
