Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Bios problem My PC affected by BIOS Virus. due to the virus system is not booting. Please let me know the solution.
  • 53 Answers
Hi Unplug the power cabel on your computer and remove the battery on the motherboard and then place it back. Good Luck
Posted on Sep 16, 2007
SOURCE:
AutorunRemover Autorun Virus Remover license code
Your note book is virus affected.
Try to system restore in earlier date. Follow the step
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
>start>program>accessories>system tools >system restore >set earlier date. If you have the strong virus you can not do that, then you should better to copy your data if necessary
follow step>set your hard disk in another computer .before install be ensure that .another pc is well condition.
>show hidden folder can see all system file >can open task manager>run type ms config >enter, it will be open windows>run type gpedit.msc> enter, it will be show.>run type regedit enter ,it will be open .think your another pc run in ok condition. Then type gpedit.msc and hit >administrative templates>system>turn off auto play>select enable>click down arrow >select all drives.
SET IT FROM BOOTH SIDE BECAUSE THERE ARE TWO SIDES >Go tools> 1 folder options>views>check on show hidden files and folders>2 check off hide extension >3 check off hide protected.
Now auto run program off. you can see and delete easily all the hidden unnecessary file .auto run file. Placed virus affected hard disk in this pc.explore drive select autorun/recycler/system volume information by dragging and delete it. Don't do the system drive for ensure r click on my computer >manage>disk management>identify system drive >and system drive letter>
Now You can copy your file and store in another drive which formatted emediate.And you can format drive one after one and transfer all the file to the formatted drive .Switch off the pc and put your pc again and install your os and set the pc same way Then type gpedit.msc and hit >administrative templates>system>turn off auto play>select enable>click down arrow >select all drives.
If you did not have the cd rom , you should create a bootable flash. follow the link.
http://articles.techrepublic.com.com/5100-22_11-5928902.html
If you want remove manually 1st click here or http://amiworks.co.in/talk/how-to-remove-new-folderexe-or-regsvrexr-or-autoruninf-virus/
If you want remove manually Autorun virus 2nd click hereOr http://www.wikihow.com/Remove-Autorun-Virus-from-Hard-Disk-Drives
You want to save your data download
http://www.hiren.info/bootcd-on-usb-disk
Write cd with the ISO and restart pc cd will start soon, click here or http://www.windowsreinstall.com/articles/bios/ for BIOS SETUP and go mini windows and deletesystem volume information and RECYCLERfrom all drive except "C"
drive. Because Heart Of Castle.If can not remove download bootable f cecure,click here or http://www.techmixer.com/free-f-secure-rescue-bootable-cd-to-clean-virus-and-malware/b>And write the ISO and boot from CD at the start time.SET THE BIOS SETUP for BOOT FROM CD
http://www.windowsreinstall.com/articles/bios/DONT USE KAV because it will delete your windows file
Now you will install and just delete C drive and create C drive same andinstall.
Installation guide click here.http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
Hope this helps. Let me know if you need more informationThanks
shibuda
May 11, 2011 | Computers & Internet
I can't use transcend pendrive in windowsxp please send me the solution
Hello, Your note book is virus affected. Try to system restore in earlier date. Follow the step How will you confirm? Follow the steep. Press win key +R >type gpedit .msc andsoon an windows will open. Press win key +R>ms config and soon an windows will open. Press win key + R REGEDIT an windows will open soon. Go to tools option >folder option >view>check onshow hidden file Check off hide protected operating system file Check off hide extension known type file. BUT still there are no hidden file in drive C: Think your computer has affected by serious virus. >start>program>accessories>system tools >systemrestore >set earlier date. If you have the strong virus you can not do that,then you should better to copy your data if necessary follow step>set your hard disk in another computer.before install be ensure that .another pc is well condition. >show hidden folder can see all system file >can opentask manager>run type ms config >enter, it will be open windows>runtype gpedit.msc> enter, it will be show.>run type regedit enter ,it willbe open .think your another pc run in ok condition. Then type gpedit.msc andhit >administrative templates>system>turn off auto play>selectenable>click down arrow >select all drives. SET IT FROM BOOTH SIDE BECAUSE THERE ARE TWO SIDES >Gotools> 1 folder options>views>check on show hidden files andfolders>2 check off hide extension >3 check off hide protected. Now auto run program off. You can see and delete easily, allthe hidden unnecessary file and auto run file. Now install virus affected hard disk in this pc and startDONT LET DO SCAN .Explore Your all new partition select (DONT CLICK ON )only by draging the autorun/recycler/system volumeinformation and delete it. Don't do thesystem drive for ensure r click on my computer >manage>diskmanagement>identify system drive >and system drive letter>It will bewritten SYSTEM. Now You can copy your file and store in another drive whichwould be formatted emediate.And you canformat drive one after one and transfer all the file to the formatted drive.Switch off the pc and put your pc again and install your os and set the pcsame way Then type gpedit.msc and hit >administrativetemplates>system>turn off auto play>select enable>click down arrow>select all drives. If you did not have the cd rom , you should create abootable flash. follow the bellow link. http://articles.techrepublic.com.com/5100-22_11-5928902.html If you want remove manually 1st http://amiworks.co.in/talk/how-to-remove-new-folderexe-or-regsvrexr-or-autoruninf-virus/ If you want remove manually Autorun virus 2nd http://www.wikihow.com/Remove-Autorun-Virus-from-Hard-Disk-Drives You want to save your data download http://www.hiren.info/bootcd-on-usb-disk Burn cd with the ISOfrom image burning option and restartpc, cd will start soon, http://www.windowsreinstall.com/articles/bios/ for BIOS SETUP and gomini windows and delete system volume information and RECYCLERfrom all driveexcept "C" drive. Because Heart Of Castle.If can not remove downloadbootable f cecure, http://www.techmixer.com/free-f-secure-rescue-bootable-cd-to-clean-virus-and-malware/ b> And write the ISO and boot from CD at the start time.SET THE BIOS SETUP for BOOT FROM CD http://www.windowsreinstall.com/articles/bios/ DONT USE KAV becauseit will delete your windows file Now you will install and just delete C drive and create Cdrive same andinstall. Installation guide WIN XP http://www.windowsreinstall.com/articles/bios/ http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx VISTA http://vistaultimate.windowsreinstall.com/repairstartup/repairstartup.htm If you need more information, reply me soon. Thanks
Feb 25, 2011 | Computers & Internet
My pen drive don't show any memory. it also shows" please insert a drive into disk" when i tries to open it.Also disk management don't shows my pen drive
Often curser in my desktop frozen,what should i do?
It may be your pc affected by virus,
Doesn't work properly
Thanks for using Fixya,
You can increase the ram .
I think your computer affected with serios virus ,or you have install unnessery software ,so please
un install un nessaery software and scan with f secure bootable cd .
Try to clean the virus Download bootable f-secure,bootable cd or http://www.techmixer.com/free-f-secure-rescue-bootable-cd-to-clean-virus-and-malware/> And burn the iso file ,under image burning option withany nero(major user take it wrong and burn under data option ,and it cannotboot from cd) and boot from cd at the start time. Go for bios setupand boot from cd (If you don't have any concept)
http://www.windowsreinstall.com/articles/bios/ Don't use kav rescue cd , because it will delete yourwindows file.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 20, 2011 | Computers & Internet
I'm using mercury mainboard kvm266pm-u with sempron cpu but it freezes a few minutes after i start up the PC, even in bios set up. the link for bios update to the main site is not working. how do i solve...
Is your CPU and HSF fitted correctly?
Usually if you get freezes and shutdowns it is due to overheating.
You may also have a virus/malware infection.
Boot into safe mode with networking (F8)
turn off system restore
Run a virus scan
Download Malwarebytes and give it a full scan.
If this is not your problem please write back
Aug 15, 2010 | Mercury KVM266PM-U (KVM266PMUD1600)...
I recently had a huge virus attack on my laptop and there is still this worm that my system picks up but not my anti virus i need to format my laptop but it does not seem to want to boot from the cd what...
Take a can of air and blow some air onto the laser gently to make sure no dust or dirt is affecting it.
Then go into the BIOS and make sure the cd-rom is the first boot device. Then put your operating system cd into the drive and "press any key" when that message comes up so the system can boot up off of the cd.
If after setting the cd-rom as the 1st boot device you can't get the laptop to boot up off of the OS cd then that means the cd-rom is bad and would need to be replaced. When you boot up off of the cd-rom your in DOS and any viruses or worms wouldn't affect it.
Jan 15, 2010 | Lenovo 3000 N500 Notebook
Have a virus and wont let me run my norton disk to put anti virus ware on the computer
You will need to use an alternate boot CD to boot your computer.
Here is a link to one such download which you will need to burn a CD. It also includes instructions on how to set your system BIOS with step by step instructions...
http://www.prime-expert.com/ebcd/getting_started.php
You should download Windows Malicious Software Removal Tool to a USB flash drive and run it to get rid of the virus affecting your harrdrive...
http://www.microsoft.com/downloads/details.aspx?FamilyID=ad724ae0-e72d-4f54-9ab3-75b8eb148356&displaylang=en
Nov 19, 2009 | Symantec Norton Internet Security 2009...
Information about virus.
The CIH virus infects executable files and is spread by executing an infected file. Since many files are executed during normal use of a computer, the CIH virus can infect many files quickly.
There are several variants of the CIH virus. Some activate every month on the 26th, while other variants activate just on April 26th or June 26th. Once the CIH virus activates, the virus attempts to erase the entire hard drive and to overwrite the system BIOS. Some machines may require a new BIOS chip to recover if overwritten by the CIH virus. CIH only affects Win95/98 machines.
More technical details about the CIH virus can be found at the following site.
Go here for more information
http://www.cert.org/incident_notes/IN-99-03.html
Hope this is some good knowledge base for your project.
http://www.virusbtn.com/VirusInformation/cih.html
May 26, 2009 | Computer Security Systems CSS-A760S...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
