Question about Kitchen Ranges
No heat on the upper oven bake and broil elements
Maytag CWE5800ACB 24 in. Electric Double Wall Oven. Top oven has a (ERC) electric control panel and the bottom has a knob controls. The problem is in the top oven. It stopped heating both in bake and broil. The bottom oven works fine. Was using the top oven on bake and it stopped heating. Bake, broil and self cleaning is not doing anything as far as heating. Checked the ohms on both elements and they are 18 and 24 ohms. Getting 120 volts to both side of the elements when I ran a test. ERC controls seem to be working properly as far as the different controls, but I keep hearing a light clicking in the controls. I still get 120 volts on both sides of the elements all the time. I do have the digram and have followed out the lines and all seems ok.
  • 16,847 Answers
I gather you are measuring voltage with respect to the chassis ground?
Shows the internal wiring for the unit. The parts are rather expensive and some are no longer available.
Posted on Mar 23, 2017
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
  • 878 Answers
SOURCE: Whirlpool oven that does not broil
Nabril, looks like you have a thermal fuse in the broil circuit. Take your meter and on the control board go to connector P2-2, should be a blue wire. Pull the connector off and see if you have continuity from the blue wire to the red wire on the terminal block (where the cord connects) power off, wires off. If you don't have continuity, it's probably that fuse. If you do, the only other thing I would think it could be would be the relay itself. The schematic does not show the placement of this fuse. It could be on the back panel or under the main top. Check out the pic. Part number..3196548 back.
Posted on Apr 21, 2007
  • 833 Answers
SOURCE: Oven will not bake or broil
bann...why did you replace the element? It is possible that the relay or the control circuit were the problems and still are. The hi limit switch is a temperature 'box' which is designed to open the circuit in case of overheating. Rarely a problem. First, these units are 3 wire units. That means 220 volts ... two breakers. They may be part of a linked unit or separate. Turn them BOTH off and then on. Do all of your burners heat properly on high? If you have a voltage tester, you can test to see if the voltage is there. Unplug the unit. The vertical slot is neutral. Each of the other slots with the neutral should light the tester. If not, your problem is outside the stove.
Posted on Dec 12, 2007
  • 2651 Answers
SOURCE: Amana Range, Electric wont bake or broil
the fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Posted on Mar 24, 2008
  • 107 Answers
SOURCE: JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Posted on Mar 14, 2009
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Maytag electric oven model cwe5800acb. The lower element in the upper oven will not heat up. Can the lower element be replaced without removing the oven from the wall.
Yes, replace the lower element by first turning off the circuit breaker to the oven (110V is still to half of the 220V element circuit even though the oven setting is turned off), then unscrew the two screws holding the element to the back wall of the oven, then pull the element out (may have to tug it a bit to get the connectors through the insulation), and pull the wire connector clips off the element.
Mar 14, 2011 | Maytag CWE5800A Electric Double Oven
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Nov 28, 2010 | Frigidaire 30" Built-In Double Electric...
Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Mar 23, 2010 | Jenn-Air JJW8230D Electric Double Oven
Maytag electric oven Model MER5755QAQ will not heat past 100
Sorry to say but the erc or eoc has gone bad. The oven control is part # 74009212 at about 200.00. Sorry for the news but it is the problem. Hope this has helped.
Feb 02, 2010 | Maytag MER5775Q Electric Kitchen Range
Bottom Baking element not working
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Sep 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Delonghi range oven
Bake- Normal convection- both upper and lower heating elements.
Conv. Bake- Semi-forced convection- both upper and lower elements, heat is then distributed throughout the oven via the fan.
Broil- radiation- The heat is radiated by the ifrared broil element.
Broil & Fan- Radiation and Ventilation- The radiated heat from the infra-red broiling element is distributed throughout the oven via the fan.
Mar 12, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Kitchen Ranges Logo
183 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
