Question about T-Mobile Dash Smartphone
My T-Mobile Dash won't vibrate anymore. I didnt use it for a couple of months and when I first started using it again it vibrated but then it just stopped.
Mmm well I don't know if its just a problem with the peice that vibrates for you, but I know that my phone did the same. You can just go into the vibrate settings under the ring type, and edit the vibrate type all to a sound, and then back to a vibrate, and that should fix it. If not it could be internal.
Posted on Apr 18, 2009
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
Vibration in dash of 2005 ford focus
Is it the dash vibrating or is because of wheel vibration? Generally the dash is pretty sturdy and unless its been in a major prang and the panel beaters have missed putting some of the screws back, it shouldn't vibrate. If the vibration starts at a certain speed and the steering wheel vibrates too, I would say its a wheel balance problem. Any Tyre place should be able to rebalance the wheels and sort this out for you. There is a possibility of a drive shaft vibration but im not sure how you check that out. If it is the dash, then good luck... There are many screws, bolts etc that hold the dash together, You will have to by trial and error , see which one is loose or missing. Before you do anything though, check that nothing is loose and rattling or vibrating in your glove box, ashtray or tissue holder. . There used to be this ad on TV showing a Guy who stripped his entire dashboard down to fix an annoying rattle. When he was looking at the hundred parts or so lying on the driveway, he found a couple of spare coins nuts and bolts rattling around in the ashtray which was the cause of the rattle!
Oct 07, 2014 | 2005 Ford Focus ZX4
Kurio 7 won't hold charge. When pluged into charge it feels like it is seizing up and vibrates.
Don't most electrical/electronic equipment have a 12 month warranty at lest, Batteries 6 months, well here in Aus it's how I am aware it is. Anyway if you can and have warranty take it back, that's all I can suggest.
May 15, 2013 | Techno Source Kurio Kids Tablet With...
1998 isuzu trooper vibration problem under load. Tires were just balanced and rotated. It has been getting worse over the last 2 months. New ujoints on the drive shaft. Still has a vibration when...
I would next check the condition of the engine, transmission and transfer case mounts. The mounts all have rubber inserts in them to absorb vibration and if the rubber starts to deteriorate or drycrack it can cause a vibration, especially under load.
Nov 22, 2009 | 1998 Isuzu Trooper
Dash does not vibrate??? anyone help
It does vibrate! All you have to do is hold down the # button for about 3 seconds and the let it go. The phone will vibrate once, and then it will have the "vibrate" icon at the top of the screen to let you know that it's on vibrate. To turn it off of vibrate, hold down the # again for about 3 seconds. Hope this helps!
Mar 08, 2009 | T-Mobile Dash Smartphone
Vibrate on
good day ! you need bring your phone to the cellphone technitian to check the vibra motor or the setting of your phone , if the setting is good thats mean the problem is the vibra motor or the vibra driver ic try to replace that ! good luck ! ...
Sep 09, 2008 | Sony Ericsson W200i Cellular Phone
Dash Keeps Vibrating
there is no option in your phone to disable or prevent the phone from vibrating, so you will have to do a clear storage....to do this, go into start, accessories, clear storage. enter 1234 and select YES.
WARNING: this WILL delete all information stored on your device, so sync it to your computer first.
Apr 28, 2008 | T-Mobile Dash Smartphone
My phone won't vibrate (Sanyo Katana)
I have the same prob just today it stopped vibrating all together. But my phone came all messed up because it didnt have some prgramming codes in it so the sprint pace on the phone had me practactly hack the matrix of my phone. It was pretty interesting, but anyway yeah i have the same prob thinking of upgrading.
Nov 04, 2007 | Sanyo Katana SCP-6600 Cellular Phone
Does not vibrate
Check mobile settings vibrate option should b on if it is on then visit service center
Gizmo1
Oct 23, 2007 | T-Mobile Dash Smartphone
T-Mobile Dash Smartphone Logo
388 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
