Question about Bosch WFR 145 Front Load Washer
How to replace rubber door seal
I would like to replace the rubber door seal of the machine.Can you provide the step by step proceedure to do this .
  • 209 Answers
When you open the door you find a this wire clamp round the edge of the door seal, this just comes off with little force, this has to go back on obviously so don't bend it, the door seal just folds back on itself, the clamp on the drum end is often a large thin spring, and that also just pulls off, the seal then also comes away with a little pull, the new seal is fitted with the groove either side of the drum lip, then the spring is put back, take note how all is removed before working on it? the front of the seal is fitted then the wire, close the door to check a tight but easy fit, check for any leaks and correct fitting before leaving machine unattended any time, sound worse that what it actually is, if i have helped rate me,
Posted on Sep 16, 2007
  • Bosch Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
Posted on Jul 22, 2013
How to put the rubber gasket/seal back on door
If you are referring to the door bellow (gray rubber seal), the following link explains step by step how to replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you require replacement parts, you can purchase them from any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer competitive prices, so shop and compare. The first three sites on the list include helpful exploded view parts illustrations to assist you in locating and properly identifying any parts you may need.
If the bellow has simply come loose and is still intact with no rips or tears, skip down to step 12 in the link I provided.
NOTE: Overloading the washer can cause items to get caught in the bellow and pull it loose, or cause premature wear.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Aug 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Replace rubber seal
If you are referring to the gray rubber door seal (called the bellow), the following link explains step-by-step how to change the door bellow on a Whirlpool Duet series front loader:
Replacement parts can be purchased at any of the following web sites:
repairclinic.com
I have found these sites to be reputable and provide great service. Prices differ between them, so shop and compare. The first three sites I've listed have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions about this repair, please post back and let me know. If the link does not take you directly to the instructions I provided, copy and paste the link to your web browser. I hope you find this information helpful.
Apr 30, 2010 | Washing Machines
Rubber seal on whirlpool waasher
If you are referring to the rubber door bellow, the following link explains step-by-step how to replace one:
If you have any questions about this repair, or require additional assistance, please post back and let me know. I hope this helps you.
Jan 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bought new rubber seal for whirlpool but no instructions how to fit.has 2 wire rings front and back of seal so how do you fit them around the new seal. do you work from the back of rubber seal first ie...
this is why we are paid to do the tricky stuff. Ok, remove the lid then open the door. look for the front pring loaded wire then remove. Pull front of seal off ridge then bend it back into the tub so it allows you to work easier. you will now see a second large ring holding the other end of the seat to the tub. remove it then pull the faulty seal out. Follow same proceedure putting it back. careful not to tear boot as it is silicon.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rubber door seal replacement on my Front Load Washer
OPEN THE DOOR
THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
TAKE OFF THE CLAMP
FOLD THE SEAL BACK INTO THE DRUM
YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
FIT A NEW ONE IN REVERSE ORDER.
HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
Jul 06, 2009 | Whirlpool Washing Machines
Bosch Axiss washer front door seal replacement
Remove the top of the machine(screws are at the back).
Look down the side of the front door on the inside of the machine.
You will see a metal wire band holding the rubber on.
You usually only need a screwdriver to loosen the screw which holds it tight.
Try it out and get back to me if you get problems
good luck
Jan 31, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Sep 02, 2008 | Kenmore Elite 45986 Front Load Washer
Rubber door seal rip...
The rubber door boot (bellow) commonly wears out on these front loaders. A replacement will run you about $80 just for the bellow. Labor could run as high as $180 if you decide to hire someone to replace it for you. If you wish to perform the repairs yourself, post back with your intentions and I can provide you with step-by-step instructions on how to replace it. It is labor intensive as you will have to remove the entire washer front in order to do the job right. It IS possible, however, if you wish to pursue a repair option on your own. Just let me know.
PS I can also provide you with the part number if you reply with your washer model number (found along the door opening).
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Small crack in rubber seal
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Aug 06, 2007 | Bosch WFR 145 Front Load Washer
Bosch WFR 145 Front Load Washer Logo
288 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
