Question about Samsung YP-K3 MP3 Player
Samsung KP-K3 MP3 Player - Charging battery
When we purchased it it only showed 1 bar on the battery. Should it show 3 when fully charged or no bars. I feel really stupid but no matter how long we charge it still shows only 1 bar. If someone could help it would be greatly appreciated.
  • 1 more comment
  • Anonymous Jul 25, 2008
    i have the same problem. i just bought it today witch is the 24 and i open the box and i turned it on it was only one bar but then when i charged it for like a couple of hours and it still showed one bar can u help me figure out the problem?
  • Anonymous Aug 27, 2008
    i charge it and it wont charg send my a mesage on www.myspace.com/gayfagumas
  • Anonymous Sep 07, 2008
    i'm having the same problem although i've had
    mine for a while now but even after two hours of charging it only has one bar
Wen i first got myn i had the same problem i plugged it and left it plugged in for a couple of hours and it showed there bars and was fine i dont quite no wat i did but i suggest double checking you have plugged it in prople sorry if im no help x
Posted on Oct 03, 2007
SOURCE:
My mp3 player says it's fully charged when I connect it but when I disconnect it and try to turn it on it says ''battery dead''.
your battery is most definitely faulty. The reason why you can charge it is your device uses the AC Charge while charging th battery. even when it says "Charge Complete", it is still charging the battery. Have the device sent for warranty repair.
Aug 27, 2009 | Samsung YP-K3 MP3 Player
My samsung p2 will not turn on...
battery can fully charged but if contacts of the tray are dirt than no current can pass through. firstly check contacts, switch showing that it is come out, after pushing it in, also check for polirities of batteries.
Mar 25, 2009 | Samsung YP-K3 MP3 Player
My computer will not reckonise my samsung k3 mp3 player
connect your samsung to a computer usb, go to my computer, check for removable e or f , with the samsung connected go on the net and type search samsung k3 mp3 player software. the computer it self will select a software to down load.
Mar 07, 2009 | Samsung YP-K3 MP3 Player
I hav a phone problem and a samsung 1gb mp3 player
both of your device have some hardware problem send it to service center for details checking.
Jun 20, 2008 | Nokia 6600
Charging
Hello kings_park,
I would agree with what the tech support agent(s) told you. What you are describing sounds like a bad battery. The Insignia® Piliot MP3 players have a one year limited warranty. For service you should take the MP3 player into your local Best Buy™ store with the receipt. The store will be able to assist you in diagnosing the problem and if needed having the item serviced or replaced.
Best Regards,
Ken
"Go Ahead. Use Us."
May 29, 2008 | Insignia Pilot MP3 Player
Yp k3 player wont charge....
O NOW LISTEN 2 ME CAREFULLY I HAD THE SAME PROBLEM the nokia charger which is there u can use that by getting a connector the connecter is a small type of wire and it is really helpful u can try in any electronic store near ur house i can try sending it 2 u if ur in india it comes hear for Rs20 now it even charges faster
Apr 22, 2008 | Samsung YP-K3 MP3 Player
Samsung MP3 not charging
Get the driver from:
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=&dType=D&vType=L&mType=&model_cd=&menu=guides&prd_ia_cd=&acc_ia_fl=&disp_nm=YP-K3JAB&isEqualsY=Y#
Mar 13, 2008 | Samsung YP-K3 MP3 Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
Brand new Samsung YP-K3 charging FOREVER..
well have had my k3 die on me once, pressed reset on the back and it worked again (this in the it doing nothing anymore case) as for the cgarging thing try it on another computer, when I charge my k3 at work it charges all day but I don';t get a full battery, at home I charge it for bout 2 to 4 hours to get full battery. I think it has something to do with ho many things u have connected to ur usb ports or how much output ur computer gives to ur usb, maybe it goes to like a lower voltage to preserve electricity, no idea how to change this but unplug unneccecary things.
Dec 09, 2007 | Samsung YP-K3 MP3 Player
Samsung YP K3 only lasts for 2 hours
1. totally discharge the battery so it wont come on.
2. Charge the battery fully
3. Reset the player
Now check how long the battery lasts. If it is still 2 hours there is a problem with the battey and you will need to return the player.
Oct 29, 2007 | Samsung YP-K3 MP3 Player
Samsung YP-K3 MP3 Player Logo
775 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
