Question about Bosch WFR 145 Front Load Washer
Rubber door seal
I have black mould growing on the inner surface of the rubber door seal. I have tried to clean with bleach and ammonia dertegent blend. Mould still remains. Do you have a suggestion as to how to succesfully remove this black mould.
4 Suggested Answers
  • 1294 Answers
SOURCE: Zanussi front load washer door seal
Keeping the door open after your wash would help in keeping the interior dry. Do not push the door shut, just leave slightly open. Only before you begin your wash, check to see your cat is not inside.
Posted on Jan 02, 2008
  • 99 Answers
SOURCE: mould and mildew forming around
you need to do a 90degree wash reguarly.
Posted on Oct 11, 2008
  • 4059 Answers
SOURCE: The rubber seal at the front of the machine has
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Posted on Oct 21, 2009
  • 56589 Answers
SOURCE: black mould
this is the fatal flaw of front load washers, see this complaint over and over, use bleach to clean it or Tilex mold and mildew remover, make sure the hole that drains the seal is clean.
Posted on May 13, 2010
0 characters
1 Points
Smelly washing machine
Hi Haydn.
One of the main reasons for smelly machines is because the door is left closed and mould is growing in the drum and door seal.
Using some chlorine bleach will help. Put some in the drum and do a 'Rinse & spin'.
Leaving the door slightly ajar will allow the drum to dry and it will also allow the rubber seal to relax, thus maintaining a good contact with the glass when in use.
Once it's established mould can be difficult to get rid of entirely.
Good luck.
Jan 11, 2015 | Bosch Washing Machines
How do i clean Bosch WAE20261AU front loader washing machine
The lint will be in a removable filter and as for cleaning the rubber seal the black grime will most likely be mould. Try a good mould remover.
Apr 27, 2013 | Washing Machines
I have a 18month Electrolux 8kg front loader which has mould on the bottom part of the rubber seal. I have always kept the door open after every wash but the mould has set in. I have tried wiping it with...
You will find that wiping it dry, then painting it with thick household bleach and leaving it overnight will have an excellent effect on the staining. The rubber will tolerate the bleach without any problem. If one night doesn't quite cut through the mould, treat again the following night.
Just remember to wash the bleach away thoroughly, so that it doesn't affect any garments in the next wash!
Jul 29, 2011 | Washing Machines
Black mould
May 13, 2010 | Zanussi ZWF1440 Front Load Washer
Mould/gunk on the rubber seal of a Maytag MAF1300 AAW - help!
Once mold is present the only way to get rid of it is with peroxide. Any residue left will grow again.
May 13, 2010 | Washing Machines
How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Sep 08, 2009 | Washing Machines
Is there a way to clean rubber seal around the opening?
Use a vinagar solution to clean the rubber seal. bleach will damage the rubber.
Apr 29, 2009 | Washing Machines
Bosch WFR 145 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Richard Roth
Richard Roth
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
