Question about IBM 6400 Matrix Printer
Paper not advance
Hi, my problem is that the printer can´t up the paper, when close paten the motor is very hard and not up the paper...
thank´s for your help....
  • 1,602 Answers
THE ROLLERS MAYBE DRYED OUT AND THEY NEED TO BE RECONDITIONED, OR NEW RUBBER PUT ON THE ROLLERS.
THERE IS A WAY TO TURN THEM DOWN YOUR SELF BUT YOU COULD ALSO MESS THE EVENINGNESS OF THE ROLLER, A SHOP THAT WORKS ON PRINTING PRESSES MAYBE ABLE TO HELP YOU OR IBM SERVICE CENTER MAY HAVE SOME OTHER IDEAS OR DO THEY EVEN MAKE PARTS FOR THAT PEACE OF EQUIPMENT.
ROD
Posted on May 12, 2009
After refill my cartridge firstly it shows cartride is not properly installed.After that when we give print command it shows service error 5010. my printer is pixma mp 140.
Error 5010 Possible solution. I did this and it worked but I do not know if the solution is related to the printer's error code. 1. Unplug printer....wait 30 seconds then plug it in. Make sure the unlock symbol is on unlocked. you can find this when you lift up the heavy top cover to see the paten. 2. Reset. Turn off. Turn on. Reset 3. If this does not work. Look inside close to where the paper comes out (from the front.) There is a little door that can be flipped up or down. Flip this door up. Repeat steps 1 and 2.
Jan 19, 2011 | Canon PIXMA® MP460 All-In-One InkJet...
I keep getting a printer jam error for the hp officejet 8500 wireless, no paper jam, have done everything HP suggests and still won't work. Can anyone suggest what to do other than buy a new printer?
Hi
This is a coomon problem with the printer the best thing to do is call HP and advise them of the issue. I recently had a customer who did this and even know it was out of warranty they replaced the printer.
Thanks
Daniel
HP Technician
Nov 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
'move fric.lever' message. Kindly please explain. Thanks
It is telling you to move the friction lever.
The friction bar holds the paper against the platen roller, it must be in the closed position to advance the paper.
The lever should be to one side of the roller.
Jun 29, 2010 | Dataproducts 8524 Matrix Printer
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
paten glass is the copy board glass.try cleaning both side,if still same.it can be off in additional funtion [copy board glass sign.turn it to off ]
Mar 17, 2010 | Canon imageRUNNER 1023iF Black and White...
The printer Hp PSC 1610 Don´t take the paper
Press the slide between youre fingers and it should move along.
It should be on the left handside and not on the right.
Mar 05, 2010 | HP PSC 1610 All-In-One InkJet Printer
My copier says Paten is open closet paten. but everything is closed. what do I do?
Each lid has its sensor. Usually this salients on lid, you it is necessary attentively to look, what salient overlays the sensor salient on lid, can be comes short quite little, arouse to press the lids by turns.
Unless it is got, follows to apply to service, sensors mortality, is violated contact to sensor, the sensor has forfeited its place.
Oct 06, 2009 | Office Equipment & Supplies
Hp all-in-one ->Paper Jam: Clear jam, and then press OK error message
it may have more to do with the type of paper and your canon printer. did you check to see that the paper is compatible with the printer specifications?
Apr 22, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Printer WILL NOT LOAD or ADVANCE PAPER
I have the same problem with my epson CX3810. Paper won't load or advance. Any solutions???
Feb 13, 2008 | Panasonic KX-P2023 24-Pin Impact Printer
HP design jet 450C inkjet Media Error`
Clean the Paper sensor which is down button use to feed the paper & the paper edge sensor on the carriage unit
Jan 09, 2008 | HP DesignJet 450c InkJet Printer
IBM 6400 Matrix Printer Logo
57 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
